Results 1 to 3 of 3
    Default Freightliner C2 TCM location needed
    Last 6 of vin
    X09856
    Trying to find the TCM, I have a C2 manual but it says the tcm is on the left frame rail between the battery box and the front wheel well, I looked and it is not there. In between the wheel well and batteries there is a webasto heater mounted in a box.
    Followed all wiring around the heater thinking maybe they ran an extensnion harness and relocated but found nothing.
    I do see a wabco ecm behind the right dash, but no tcm.
    thanks,
    josh
    DK Veteran RSwire's Avatar
    your girlfriends house
    Did you look on the inside of the frame rail, I've seen lots mounted right next to the trans on inside the left framerail, usually in side a little box or cover.
    A DAY YOU DIDN'T LEARN SOMTHING NEW IS A WASTED DAY.
    Please don't pm me for keys, that is what the forum is for.
    If it helped, please use the thanks button, if thanks isn't enough use the scales.
    I just got a picture from thomas and they say its inside the vehicle on the right firewall behind a cover, next to the step heater.
    they also corrected me as it is a FS65 chassis not a C2
