Results 1 to 15 of 22
    obdmaster's Avatar
    Never never land
    Question rover turbo MKC 101960 decode
    In the morning i have a 1995 rover coupe turbo ecu to decode, its old style unit with DIP 93c46, instead of surface mount.
    Because its dip cant remove as i usually do.
    Now heres my question next to another chip there an oscillator, because im going to do this in circuit, do i link oscillator or not.
    Im going to use data explorer manager to decode it. Is that ok for this old type ive used it on newer with surface mount 93c46, with success but not on this older version.
    Many thanks
    Obd.
    You need every tool in the book, to do this auto locksmith job.
    damih's Avatar
    france
    Hello,why you don't desolde the chip with hot air and read with Xprog in board ?
    obdmaster's Avatar
    Never never land
    Wink
    Quote Originally Posted by damih View Post
    because the chip is Dip and covered in green goo,underneath the chip and over it, holding it down. If it was surface mount i would be able to use hot air
    On the move
    Quote Originally Posted by obdmaster View Post
    Hi!
    I remove the goo with paint thinner, hope this helps
    Br,
    Mike
    damih's Avatar
    france
    Hello,when i do this job i use brake cleener (acetone) to clean this gum and after i use aluminium tip to put around a chip i put some flux on a chip and after i use hot air and job done (disassemble a PCB)
    this chip is like bosch MP and MSA
    obdmaster's Avatar
    Never never land
    First of all tried in circuit with xprog-m, it would read ok, but not write immo file with oscillator shorted or not, then tried with UPA and after cutting track it read and wrote here are my two files, does anyone have immo off file to check for mkc101960 to check mine, as car is far away.
    Many thanks
    Obd.
    damih's Avatar
    france
    Default Im*o off
    Hello,here you go 100% tested sorry for a delay i travel for job
    read pdf and note pad
    Pass in MP
    obdmaster's Avatar
    Never never land
    Wink
    Pass in MP
    Well its completely different than m8, if mine dont work will try yours thanks.
    Customer still hasnt picked ecu up.
    Meat-Head's Avatar
    bump spam, just snooping arond, only just see this thread.
    Dreamal the chip off, then solder wire links on, if you have to.
    Rumor going around 'any' rover one will do - search for 'dead-metrot' thread.
    hth
    Meat.
    obdmaster's Avatar
    Never never land
    Thumbs up
    hth
    Meat.
    No m8 any rover rover dump wont do. for K series: 1.1, 1.4, and 1.6 yes.
    Did T series non turbo before xmas, immo off. Different immo off file again than k series, but SCP changed dump in same places. And it worked.
    T series turbo, must be working with my dump as customer not phoned moaning. Again different file from k series and T series non turbo, but again SCP changed dump in same places.
    Meat-Head's Avatar
    *CONFUSED*
    Rename the files, K-serires, T-series etc then upload to this thread.
    Remember to password the files with a stupid password - to piss folks who are good members of this forum, who are in need of a file - then when folks pm you for the password - ignore them, or tell them no!!!!!!!!!
    Meat.
    obdmaster's Avatar
    Never never land
    Thumbs up
    *CONFUSED*
    Meat.
    text me your email m8, i will send you set when at work.
  13. #13
    Meat-Head's Avatar
    Just stick @orange.net on the end of my mobile number, , simple.
    remember "07xxxxx" not "+447xxxx"
    Meat.
  14. #14
    Default help please
    I've similar car and need immo off too, could I have pass please?
  15. #15
    damih's Avatar
    france
    Hello,I have send you a pass
