Page 2 of 2 FirstFirst 12
Results 16 to 30 of 30
  1. #16
    joubliss's Avatar
    Jan 2010
    Far away
    Ad900 clone use a precoded chips, dont use a blank chips like Zedbull and others......
    for example if u want to make a key from a dump with Ad900 u have to do it with a precoded chip for this cars.... but with other tools like Zedbull u can use a T5 or sometimes a blank pcf7935 to do the job.
    i suggest to buy a genuine tool that use a blank chips and generate most chips......
    job
  2. #17
    Top Poster key point's Avatar
    Jan 2010
    UK
    Quote Originally Posted by joubliss View Post
    job
    the ad900 uses precoded chips for the cloning of some chips but if you are making a key from the dump you never use precoded 99 chips you just use T5 or pcfs like the zed bull.
  3. #18
    joubliss's Avatar
    Jan 2010
    Far away
    Quote Originally Posted by key point View Post
    wa talk about Ad900 clone not genuine one. look at Transpronics (software of ad900 clone) and u will see what i mean.
  4. #19
    Jan 2010
    UK
    i see, not had any experience with a clone. good news if they dont work so well though.
  5. #20
    DK Veteran marginal's Avatar
    Feb 2010
    Exclamation
    Quote Originally Posted by lockbreaker View Post
    You're not gonna find TPX chips in China....not yet anyhow.
    Here: Transponder Chip
    Est Modus in Rebus !!!
  6. #21
    Top Poster + electronicar's Avatar
    Nov 2009
    Also, dont confuse the terms generating and copying chips.
    Copying is basic cloning right ?
    Please explain generating ? So the new chips for copying & generating are not the same ?
  7. #22
    Dec 2010
    I'll try to put this simple as I can. When he's referring to copying, yes, he's referring to cloning. Generating is writing the logic to the chip to be used for programming OBD, aka "coding" the chip for a sole intended application or like platform applications.
  8. #23
    Dec 2010
    Quote Originally Posted by marginal View Post
    okay, I take that back. But those prices are about the same as any legitimate supplier, plus shipping from China is a drag if you aren't buying a bazillion bucks worth of stuff.
  9. #24
    Feb 2010
    I think those prices are cheaper, but anyway ...
  10. #25
    Nov 2009
    @ Marginal
    I have AD900pro & T300 from China . I also have labtool48 & a few other universal programmers .
    I know how to solder & desolder very well & i know eeprom programming .These cheap clones have already paid themselves off with the little knowledge that i have , but i am not happy with my success rate . My supplier in China does not know their products very well so they keep sending me chips that dont work with machines they supplied . I spend TOO much time finding out why i can't copy this or that .
    Please suggest to me what to invest in if i want to be able to do almost all cars & also if u guys can supply chips that work with your machines . Back-up & support is very important because i can't send 9 out of 10 cars back unrepaired . Thx .
  11. #26
    joubliss's Avatar
    Jan 2010
    Far away
    Quote Originally Posted by electronicar View Post
    @ Marginal
    its normal with chinese tools mate, if u want to do ur job at 100% buy a genuine tool, Like Zedbull or Tmpro or Tango...... all this tools works with chiper transponders (blancks) like for pcf7935 dont need to buy precoded one just put a blank pcf7935 and it will works.
    Job
  12. #27
    Nov 2010
    Tmpro2 & Tango are very good for such things.
    Get original tools and stop wasting your time with those Chinese clones!!!
  13. #28
    Feb 2010
    @ Marginal
    Hi Electronicar.
    I can not talk about equipment which can do most of the cars as I am using Chinese clones like you so far (I intend to buy some real programmers in the near future though).
    I don't do MB, BMW, Volvo and some other makes.
    I am doing mainly key programming and not key cloning (very little key cloning).
    SBB V32 is my favorite tool, but Diagun and VAG DASH K+CAN are not bad either.
    If you want, I can give you a link to my supplier, it is a good one.
    So far, so good, the only thing I have not had the chance to work with lately is the TYP: 60 transponders that they sold me for a TYP: 68 ones.
    Hope this helps ...
  14. #29
    Dec 2010
    Far as OBD scan tool support goes, AD is great. However, their products work so well and are so easy to use, that technical support is rarely if ever needed.
    I've had AD testers for 8 or 9 years, and I've called tech support once.
  15. #30
    Feb 2011
    4c is a texas fixed code transponder the easiest way to provide another key is to clone it. you will need to clone it to a 4c module (silca eh1) if you're using the ad900, silca rw4 can clone it to a 4d module (silca eh2) aswell. so if you have rw4 you just stock 4d keys if you're using ad900 you need to stock 4c & 4d keys to be able to do the job
