I do not have x17.
I do not have x17.
am i doing somthing wrong or is magpro faulty this is 2006 galaxy 2.0tdci i get the same response on every car i try.
[ame="http://www.youtube.com/watch?v=r0C6aZOv38Y&feature=feedu"]28112011010.mp4 - YouTube[/ame]
7.31sec@203.3mph
Probably sid803 why not go after the obd
I see that the selected maximum speed. Choose the minimum speed.
busaman Other ECU using the connect of CAN, work?
i would make sure that you are reading on the slow setting,this setting does change,,,,so after it has id the ecu make sure its on the slow setting again..
MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
Yes, the speed must be chosen twice.
Maybe these machines worked by K-line?
The device is not working the CAN? Check it here http://www.digital-kaos.co.uk/forums...ml#post1341517
ive just bought one,and ive read a few cars no problem...mitsubishi lancer 2.0 readok----landrover dicovery tdv6 read ojk-passat edc15 readok-
have you checked the obd lead from earlier posts on here...
busaman
If I have helped you - click 'thanks'
i have not tried it yet but will report as soon as i get one in.
7.31sec@203.3mph
I think, you have problem witch drivers for interface magpro2.
You need uninstal software & interface drivers, and install software & driver for the first version of software clone, magpro2 V3.0.
After install version V3.0 and drivers, you can update for latest software releases, V4.2A for esemple, but never update the drivers.
Regards.
