you mean mpps or magpro?
magpro2 clone not working
and where I can buy a version that works? clone?
buy a clone and not if it works.
i have also magpro2 v5.5
i think this is a user failure/problem.
you must just use the soft that came with, no other will work.
soft and driver are coded to the hardware.
magpro2 v5.5 works both seller = look at ebay Positive Feedback!
i think the people here just want to make the ebayseller bad. thats very sad
mag pro 4.2
Lexia/PP2000 and DiagBox update without internet
http://www.digital-kaos.co.uk/forums...ternet-155768/
http://www.digital-kaos.co.uk/forums...86/#post806086
mayss (16th July, 2014)
magpro2 v5.5 is a scam. It is the exact 4.2 software but in the list you have more cars. However NONE of the new added cars work. If you want v5.5 cars buy the original.
Do you have any of the new added cars to test ?
Anyone bought from this "performance-tuning24" eBay seller ? tested ? works ? No work ?
I bought a clone 4.2 and does not work. where I can buy original magpro good price???
hi...
magpro2 clone have recovery mode edc16 ?
HELP ME !
worked perfect my magpro 2, now I have the following error:
can you help me? not understand that matter?
thank you!
you normally get this error if the car isnt listed-or maybe ignition is not on...
have you used the same ecu settings before.
MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
Look for one file created soon after you tried the car, rename it and the ECU can be tried again (some Multec I make sometimes crashes duraing write and I had to make it to magpro work again in the same ECu type)
