Page 12 of 17 FirstFirst ... 27891011121314151617 LastLast
Results 166 to 180 of 248
  1. #166
    May 2009
    Quote Originally Posted by catala20032004 View Post
    Hello can i have the pass please?
  2. #167
    Top Poster kristikapa's Avatar
    Read post 161.
  3. #168
    DDT2000 fault codes, EDC15C13:
    1801 - Coolant temperature circuit
    1802 - Air temperature sensor circuit
    1803 - Atmospheric pressure sensor
    1804 - Turbocharging pressure sensor
    1805 - Fuel temperature sensor circuit
    1806 - Air flowmeter sensor circuit
    1807 - Flywheel signal information consistency
    1808 - Camshaft sensor / engine speed consistency
    1809 - Pressure sensor circuit
    180A - Pedal sensor circuit track 1
    180B - Pedal sensor circuit track 2
    180C - EGR valve position sensor circuit
    1810 - Sensor supply voltage n***730;2
    1811 - Vehicle speed signal
    1813 - Main relay
    1814 - EGR valve
    1815 - Air intake circuit
    1816 - Preheating relay circuit
    1817 - Low-speed fan assembly circuit
    181A - Refrigerant sensor circuit
    1820 - Low pressure pump relay circuit
    1822 - Pressure solenoid valve circuit
    1824 - Swirl flap
    1826 - Heater plug circuit
    1828 - Brake signal
    1829 - Clutch contact signal
    182A - Battery voltage
    182B - Computer
    182E - Cylinder injector circuit 1
    182F - Cylinder injector circuit 2
    1830 - Cylinder injector circuit 3
    1831 - Cylinder injector circuit 4
    1834 - Heating element relay no 1
    1835 - Heating element relay no 2
    1836 - Heating element relay no 3
    183A - Flow at self-test after ignition switched off
    183E - Engine immobliser
    183F - Sensor supply voltage no 1
    188C - Water in diesel fuel sensor
    1882 - Pressure signal
    1886 - Computer
    1887 - Reversing signal
    1888 - Computer
    1889 - ?ntake flap circuit
    Own ecu:
  4. #169
    please upload anybody ddt2000 v2.5.0.0,i want test this soft
  5. #170
    Member eudin77's Avatar
    Apr 2011
    near my pc
    Quote Originally Posted by btr View Post
    read first post...and the pass is in post 16
  6. #171
    Quote Originally Posted by eudin77 View Post
    File not found...
  7. #172
    Apr 2011
    mandoria
    File not found.. the link is possible tank
  8. #173
    it is possible to virginise Sirius32 with ddt2000?
  9. #174
    Try with UCH x73 et X74 xml, it has 2 scenarios for virgin. Second may virgin card key, don't know. Test it and post results.
  10. #175
    I need to virginise ECU, not UCH
    with good key I have
    ECU - antidemarrage active
    UCH - antidemarrage inactive
  11. #176
    rotfl sry. Propably via reprogramming module if you have database.
  12. #177
    You cannot reprogram the ecu if immo is active.
  13. #178
    Top Poster georgegt's Avatar
    Romania
    It's intresting
    but where I must to put the database for ddt 2.5.0.0
    and how I can make the reprograming tool to work without error unlock imposiblr ?
  14. #179
    Romania
    I was to late perhaps topic is closed
  15. #180
    Elsewhere
    Quote Originally Posted by cosmind View Post
    Yes it is possible, read ecu , rewrite it with the same you read , and it is virgin.
    Of course the ecu must be unprotected ( start with original key ) and must have unlock sw in the ddt, otherwise you will get only errors.
