Page 14 of 17 FirstFirst ... 491011121314151617 LastLast
Results 196 to 210 of 248
  1. #196
    Elsewhere
    DDT database is indicating you the way it is searching ( the protocol ) your ecus > by a colored rhombus near the ecu name > lighyt blue for K slow init, e.g. Sirius, EMS .., green for DiagOnCAN, orange for K fast init, e.g. DCM12...
    You can see there the way your ecu is searched by the DDT, if it has a green rhombus it is seen only by CAN,
    it is orange, pink or blue ( light or dark ) you must see it by KKL interface.
  2. #197
    Oct 2008
    I am interested you can unlock the Logan 1.5 dCi computers to read and rewrite the software from them, from what I understand to be some access files
  3. #198
    Elsewhere
    Quote Originally Posted by FastFurious View Post
    Yes, i can unlock ecus from Renos, Sirius32, EMS3132 are a piece of cake to unlock, most difficult - but not impossible ! - for a DCM12. I read it but never rewritten.
    Rewriting sirius - ems is usual for me, never tryed for DCM12.
    I`ll try one of these days, but the ecu is ok, after rewriting who knows ?
    And yes, you must have some access files to do that kind of " weird " job
  4. #199
    Member joca0830's Avatar
    Dec 2011
    portugal
    kristikapa,Send me pass please,DDT2000 v 2.6.0.0
  5. #200
    Oct 2008
    Default Send me pass please,DDT2000 v 2.6.0.0
  6. #201
    Oct 2008
    Exclamation database for ddt2000 2.6.0.0
    where are you ddt2000 database 2.6.0.0?
  7. #202
    Oct 2008
    Quote Originally Posted by joca0830 View Post
    Pass is renoddt
  8. #203
    Friends sorry to post this question here, but I have an issue with DDT2000 V2.3.01 with full database that I download from this thread.
    I was reading failures of a 2004 Clio 1.6 16V for first time when it turns on the Airbag error light in the cluster when it before was off.
    I try to check out the DTCs of the Airbag module but it through me a "No Database data" when the xml archive is there. Now I can not diagnostic that module, can not read codes of that module and either can not erase the codes too.
    Anyone had this issue before? what can be done to solve it? I really appreciate your help.
  9. #204
    Top Poster kristikapa's Avatar
    Try to erase the failures using renault can clip. This should solve your problem, unless there is a real fault in the restraint system.
  10. #205
    Elsewhere
    Quote Originally Posted by eliotroyano View Post
    You have an error for first oxygen sonde ( lambda ) , first sonde on the exhaust line ( in front of the catalysator ), it seems to be broken ( error historyc and current ). This is actually lit the emissions LED on the dash.
    But you said is the driver airbag LED is lit. For viewing the airbag computer in DDT select MANUALLY airbag ecu from xml`s BOSCH ABS8X06/X35/X65/X76v1 cause DDT won`t find it automatically, but select it manually and with right mouse button > Read idetification.
    Anyway, if airbag is lit, most sure it is a wiring problem, interruption or shorts on the airbag firing lines, verify the wiring under the steering wheel.
  11. #206
    hello alfabit, do you know if a DERELEK interface will work with usb to serial adapter ?
  12. #207
    Pitesti,Romania
    derelek can is only in USB
  13. #208
    Elsewhere
    Quote Originally Posted by cosmind View Post
    No USB > serial port adapter for working with DDT.
    Anyway, a PC with serial com port and no USB must be old enough, you must get it to retirement !
    No one would be able to cram into a serial Com port ( speed max 38kbps ) the info from a CAN -bus ( min speed 250 kbps )
    Having a Derelek interface you worth a better computer !
  14. #209
    Pitesti,Romania
    for KL diagnose don't need derelek serial interface. you can use USB KKL cable for that.
    for CAN: if you have derelek v2can + ni-can interface , you can use it with usb-serial adapter.
  15. #210
    Jungle
    Why don't you use UsbDiag with CAN and K/L ALL in ONE? )
    Or UsbDiag2 or 3 ?
    Very soon there WILL BE USBDIAG on sell. Stay cool and have patience.
