Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 95
  1. #16
    bram380's Avatar
    Indonesia +628153111774
    firmware 05.04 (not test):
  2. #17
    Quote Originally Posted by jokersat View Post
    i know this step but
    always DS error , i think your firmware is for 5.01 not for 5.00
    you can send me other firmware
    to solve it
    I'm assuming the ds is a ds2432 error, seeing how the file has the serial number attached, I'd say the serial number is related and stored in the ds2432 chip, so you'd need the firmware with the correct serial or change the data in the ds2432.
  3. #18
    Question
    Quote Originally Posted by bram380 View Post
    However, the clone is a clone,
    but how can I make close to its original function,
    This exciting challenge ....
    Don't worry....
    Now you are ready to download:
    Zed-Bull Clone Firmware 05.02
    hi your zed bull is chinese? so it's possible to clone texas 4d? where did you buy? v5.08 now? and it's possible update?
  4. #19
    Can somebody help with v5.02 firmware? Password can not allow me to download. I also received Zed Bull without login card from China.
    Does somebody succeed to fix problem?
    Thanks!
  5. #20
    morocco/fbs
    not yet friend
    the problem is DS2432 Im sure must serial is the same as DS2432 serial
    Im waiting solution or i must buy new one with 5.02 no need key
    thanks for all members
    HERE IS MY ORIGINAL DUMP DS2432
  6. The Following User Says Thank You to jokersat For This Useful Post:
    Brown012 (3rd March, 2023)
  7. #21
    I can not run zed bull on R button (i got keyboard error)!
    How can I put device in update mode in order to have demand for *.zbp file?
  8. #22
    Quote Originally Posted by tihiuvek View Post
    Do not update to ANY firmware thats not made for your zed-bull
    Although it should go into update mode holding 'R' and powering on. Thats provided you've got the actual zed-bull clone (running iea software) not the rippoff clone
  9. #23
    Does somebody has solution for login card?
  10. #24
    morocco/fbs
    shit my original serial is 331C95E2000000E5 ON DS2432
    and firmware serial is 33D33002010000E6
    this is the problem
    i have 2 solution i think
    1 change ds2432 serial ?
    2 search good firmware with same serial ds2432
  11. #25
    this is the problem
    Yes thats why I said try updating to 5.04 as it gives you the actual serial number, whilst 5.02 gives you brams serial.
    You wont be able to change the ds2432 serial, but 5.02 firmware modded to your serial should hopefully work.
    I should hopefully be getting 5.02 made for my serial tomorrow, I will then compare and try to work out if theres something that can be edited, but I've got a feeling its going to use some kind of encryption based on the serial in that case we'd need firmware made for every zed-bull or get our hands on the generator that some sellers must have.
  12. #26
    morocco/fbs
    that right
    and big thanks for your help
  13. #27
    Jun 2009
    why someone not buy and program a new ds memory with the serial in firmaware ,he can try to write byte in nornal mode or swap it.
    you can programm ds many times if you do not lock that secret byte or he can use ds2431 to make a try
  14. #28
    Quote Originally Posted by gadroulll View Post
    can you change the 'burnt in' serial number of the ds chip??
    Because I'm guessing even the chinese cloners couldn't else they probably wouldn't bother having different firmwares for each serial number.
  15. #29
    morocco/fbs
    the there is no solution for broken zed bull
    china is china
    just relaxe im waiting new one with hw502 no need key
  16. #30
    Nov 2010
    Turkey
    Don't worry....
    my ***305;mmob***305;l***305;zer copy***305;ng mach***305;ne or***305;g***305;nal turk***305;sh zedbull... by istanbul electronic keys licensed
