Results 1 to 15 of 29
    Default CAT Pre Low NOX flash files and x-ref
    Hi Gang,
    As some of you may already know... I had a little problem with an old 3406E ecm. That's mostly fixed now. But it made me aware that my toolkit is in need of an older Pre Low NOX CAT crossref list. The one on the current flash disk, refers to Low NOX calibrations.
    These have high pm/interlocks for the 3406E... and keygens have problems with the high numbers(greater than 255). So I'll throw it out there... the issue...
    If kg can't generate passwords for the new calibrations...
    but they can generate passwords for the older calibrations...
    ...then that leaves DK'ers an additional reason to need a supply of those old calibrations besides the fact that they are better for engine performance.
    To my knowledge, there is no such disk floating around here. If someone has it... please post it. At the very least... there needs to be a cross reference, x-ref, crossref that list the old calibrations and their intended engines. When I needed the old calibration to make sure I could restore it if some tricks didn't work... I could not get the calibration numbers of the uprates for that engine from the current x-ref.
    Nov 2010
    All the older non low nox stuff is all pretty well now kept secret. The guys who flash the older files don't like to give away the flash file numbers or pm codes. I have never seen a cross reference list although I know it does exist, I think everyone who has it doesn't want other to have it because they think they have something nobody else does.
    Dk is freakin awesome...
    Older (Nov, 2000) CAT flash files can be found here...
    http://www.digital-kaos.co.uk/forums...tml#post958736
    Mission Accomplished!
    australia
    Default flash 09|2000
    i have the 2 dis of flash file let me know with one yuo need
    australia
    list
    australia
    Default flash file
    C-10/C-12/3176C/3196 FLASH FILE CROSS REFERENCE
    UPDATED AUGUST 8, 2000
    C-10 TRUCK 2000 MY - EPA CERTIFIED
    DESCRIPTION GOV S/N FLASH ITRLCK RELEASE
    SPEED RANGE FILE CODE DATE
    305 HP 1800/2100 3CS12000 - UP 195-8041 10 JUN 00
    1150/1050 PT
    335 HP 1800/2100 3CS12000 - UP 195-8042 11 JUN 00
    1250 PT
    350 HP 1800/2100 3CS12000 - UP 177-6989 12 NOV 99
    1350 PT
    370 HP 1800 3CS12000 - UP 177-6990 13 NOV 99
    1350 PT
    335/370 HP MT 1800 3CS12000 - UP 195-8043 14 JUN 00
    1250/1350 PT
    C-10 TRUCK '99 MY - EPA CERTIFIED
    305 HP 1800/2100 3CS1 - 11999 177-9228 6 OCT 99
    1150/1050 PT
    335 HP 1800/2100 3CS1 - 11999 177-9229 2 OCT 99
    1250 PT
    350 HP 1800/2100 3CS1 - 11999 177-9230 4 OCT 99
    1350 PT
    370 HP 1800 3CS1 - 11999 177-9231 5 OCT 99
    1350 PT
    335/370 HP MT 1800 3CS1 - 11999 177-9232 3 OCT 99
    1250/1350 PT
    C-10 TRUCK - EPA CERTIFIED
    305 HP 1800/2100 8YS1 - UP 191-2810 25 MAR 00
    1150/1050 PT
    305 HP 1800/2100 8YS1 - UP 191-2811 30 MAR 00
    (208.5? FAN-ON TEMP)
    1150/1050 PT
    335 HP 1800/2100 8YS1 - UP 191-2812 26 MAR 00
    1250/1350 PT
    335 HP 1800/2100 8YS1 - UP 191-2813 31 MAR 00
    (208.5? FAN-ON TEMP) 1250/1350 PT
    335/370HP MT 1800 8YS1 - UP 191-2817 29 MAR 00
    1250/1350 PT
    350 HP 1800/2100 8YS1 - UP 191-2814 27 MAR 00
    1350 PT
    370 HP 1800 8YS1 - UP 191-2816 28 MAR 00
    1350 PT
    280 HP 1800 2PN1 - UP 170-8077 5 MAR 99
    1050 PT
    280 HP 2100 2PN1 - UP 170-8078 6 MAR 99
    975 PT
    305 HP 1800 2PN1 - UP 170-8079 7 MAR 99
    1150 PT
    305 HP 2100 2PN1 - UP 170-8080 8 MAR 99
    1150 PT
    305 HP 1800 2PN1 - UP 170-8084 7 MAR 99
    (208.5? FAN-ON TEMP) 1150 PT
    325 HP 1800 2PN1 - UP 170-8082 10 MAR 99
    (FIELD UPRATE FOR 280 OR 305 HP IRON) 1250 PT
    325 HP 2100 2PN1 - UP 170-8081 9 MAR 99
    1250 PT
    335 HP 1800 2PN1 - UP 170-8074 2 MAR 99
    1250/1350 PT
    335 HP 1800 2PN1 - UP 170-8083 2 MAR 99
    335/370HP MT 1800 2PN1 - UP 170-8076 4 MAR 99
    1250/1350 PT
    350 HP 1800 2PN1 - UP 170-8073 1 MAR 99
    1350 PT
    370 HP 1800 2PN1 - UP 170-8075 3 MAR 99
    1350 PT
    C-12 TRUCK 2000 MY - EPA CERTIFIED
    335 HP 2100 2KS40000 - UP 177-7004 20 NOV 99
    1550 PT
    355 HP 1800/2100 2KS40000 - UP 177-7005 21 NOV 99
    1350 PT
    380 HP 1800/2100 2KS40000 - UP 177-7006 22 NOV 99
    1450 PT
    395 HP 1800/2100 2KS40000 - UP 177-7007 23 NOV 99
    1450 PT
    355/410 MT 1800/2100 2KS40000 - UP 177-7008 24 NOV 99
    1350/1450/1550 PT
    380/410 MT 1800 2KS40000 - UP 177-7009 25 NOV 99
    1450/1550 PT
    410 HP 1800/2100 2KS40000 - UP 177-7010 26 NOV 99
    1450/1550 PT
    425 HP 2100 2KS40000 - UP 177-7011 27 NOV 99
    (EMERGENCY VEHICLE, RV, AND BUS ONLY) 1450/1550 PT
    380/430 MT 1800 2KS40000 - UP 177-7012 28 NOV 99
    1450/1650 PT
    430 HP 1800/2100 2KS40000 - UP 177-7013 29 NOV 99
    1650 PT
    455 HP 2100 2KS40000 - UP 177-7014 30 NOV 99
    (EMERGENCY VEHICLE, RV, AND BUS ONLY) 1550 PT
    C-12 TRUCK '99 MY - EPA CERTIFIED
    335 HP 2100 2KS1 - 39999 177-9240 11 OCT 99
    1550 PT
    355 HP 1800/2100 2KS1 - 39999 177-9244 12 OCT 99
    1350 PT
    380 HP 1800/2100 2KS1 - 39999 177-9233 4 OCT 99
    1450 PT
    355/410 MT 1800/2100 2KS1 - 39999 177-9237 3 OCT 99
    1350/1450/1550 PT
    380/410 MT 1800 2KS1 - 39999 177-9238 9 OCT 99
    1450/1550 PT
    380/430 MT-4 1800 2KS1 - 39999 177-9239 10 OCT 99
    (STANDARD RATING OR MT-4) 1450/1650 PT
    380/430 MT-2 1800 2KS1 - 39999 177-9243 14 OCT 99
    1450/1650 PT
    395 HP 1800/2100 2KS1 - 39999 177-9234 6 OCT 99
    1450 PT
    410 HP 1800/2100 2KS1 - 39999 177-9235 7 OCT 99
    1450/1550 PT
    430 HP 1800/2100 2KS1 - 39999 177-9236 8 OCT 99
    1650 PT
    425 HP 2100 2KS1 - 39999 177-9241 15 OCT 99
    455 HP 2100 2KS1 - 39999 177-9242 16 OCT 99
    335 HP 2100 9NS1 - UP 191-2818 29 MAR 00
    1550 PT
    355 HP 1800/2100 9NS1 - UP 191-2819 24 MAR 00
    1350 PT
    355 HP 1800 9NS1 - UP 191-2820 31 MAR 00
    (208.5? FAN-ON TEMP) 1350 PT
    355/410 MT 1800/2100 9NS1 - UP 191-2827 27 MAR 00
    1350/1450/1550 PT
    380 HP 1800/2100 9NS1 - UP 191-2821 21 MAR 00
    1450 PT
    380/410 MT 1800 9NS1 - UP 191-2828 28 MAR 00
    1450/1550 PT
    380/430 MT 1800 9NS1 - UP 191-3727 22 MAR 00
    1450/1650 PT
    380/430 MT 1800 9NS1 - UP 168-7029 22 DEC 98
    (SERVICES 153-8417 - TOP 2 GEARS ONLY - MS CARRIERS CUSTOMER ONLY)
    1450/1650 PT
    395 HP 2100 9NS1 - UP 191-2822 25 MAR 00
    1450 PT
    410 HP 1800/2100 9NS1 - UP 191-2823 26 MAR 00
    1450/1550 PT
    425 HP 2100 9NS1 - UP 191-2824 30 MAR 00
    430 HP 1800/2100 9NS1 - UP 191-2825 16 MAR 00
    1650 PT
    455 HP 2100 9NS1 - UP 191-2826 20 MAR 00
    335 HP 2100 1YN1 - UP 170-8094 15 MAR 99
    1550 PT
    355 HP 1800 1YN1 - UP 170-8086 2 MAR 99
    1350 PT
    355 HP 1800 1YN1 - UP 170-8095 23 MAR 99
    355/410HP MT 1800 1YN1 - UP 170-8088 4 MAR 99
    1350/1450/1550 PT
    360 HP 2100 1YN1 - UP 170-8091 7 MAR 99
    1350 PT
    380 HP 1800 1YN1 - UP 170-8087 3 MAR 99
    1450 PT
    380/410HP MT 1800 1YN1 - UP 170-8089 5 MAR 99
    1450/1550 PT
    390 HP 2100 1YN1 - UP 170-8092 8 MAR 99
    1450 PT
    410 HP 1800 1YN1 - UP 170-8085 1 MAR 99
    1450/1550 PT
    australia
    Default flash file
    410 HP 2100 1YN1 - UP 170-8090 6 MAR 99
    1450/1550 PT
    425 HP 2100 1YN1 - UP 170-8093 9 MAR 99
    C-12 MTVR
    355/410 MT 2100 9SM00001 - UP 184-6979 18 NOV 99
    1350/1550 PT
    C-10/C-12 TRUCK EURO II CERTIFIED (NOT FOR USE IN THE UNITED STATES)
    325 HP 1900 8YS1 - UP 191-0986 44 MAR 00
    1280 PT
    365 HP 1900 8YS1 - UP 191-0987 46 MAR 00
    1382 PT
    335 HP 1900 9NS1 - UP 191-0988 37 MAR 00
    1384 PT
    380 HP 1900 9NS1 - UP 191-0989 38 MAR 00
    1384 PT
    410 HP 1900 9NS1 - UP 191-0990 39 MAR 00
    1588 PT
    325 HP 1900 8YS1 - UP 158-9979 33 FEB 98
    1250 PT
    350 HP 1900 8YS1 - UP 158-9981 34 FEB 98
    1279 PT
    365 HP 1900 8YS1 - UP 158-9983 35 FEB 98
    1386 PT
    335 HP 1900 9NS1 - UP 158-2023 32 FEB 98
    1384 PT
    380 HP 1900 9NS1 - UP 153-9616 33 FEB 98
    1404 PT
    410 HP 1900 9NS1 - UP 153-9618 34 FEB 98
    1588 PT
    C-10 TRUCK EURO II CERTIFIED (NOT FOR USE IN THE UNITED STATES)
    325 HP 1900 2PN1 - UP 120-8935 12 APR 99
    1250 PT
    350 HP 1900 2PN1 - UP 120-8951 11 APR 99
    1250 PT
    365 HP 1900 2PN1 - UP 120-8922 13 APR 99
    1350 PT
    CHALLENGER AGRICULTURAL TRACTOR
    CH75D 340 HP 2100 7ZR1 - UP 126-0591 40 AUG 96
    1065 PT
    CH85D 340/375 2100 6AR1 - UP 189-2131 39 MAR 00
    340/370/380 HP 1089/1185/1217 PT
    CH65E 320 HP 2100 7ZR1 - UP 180-7275 16 AUG 99
    1040 PT
    CH75E 350 HP 2100 7ZR1 - UP 180-7276 14 AUG 99
    1138 PT
    CH85E 2100 6AR1 - UP 180-7277 14 AUG 99
    350/385 HP 1139/1252 PT
    CH95E 2100 6AR1 - UP 180-7279 12 OCT 99
    350/385/420 HP 1139/1251/1365 PT
    CLAAS CHALLENGER AGRICULTURAL TRACTOR
    CH65E 320 HP 2100 7ZR1 - UP 180-7280 16 AUG 99
    1040 PT
    CH75E 350 HP 2100 7ZR1 - UP 180-7281 14 AUG 99
    1138 PT
    CH85E 2100 6AR1 - UP 180-7282 14 AUG 99
    CH95E 2100 6AR1 - UP 180-7284 12 OCT 99
    HYDRAULIC EXCAVATOR
    345B 312 HP 2000 7ZR1 - UP 188-2148 37 DEC 99
    942 PT
    345B II 344 HP 2000 7ZR1 - UP 192-5574 51 MAR 00
    1042 PT
    365B 412 HP 2000 6AR1 - UP 191-0615 3 FEB 00
    1244 PT
    3176C MARINE
    450 HP 2300 6BW1 - UP 189-2566 42 MAY 00
    1336 PT
    525 HP 2300 6BW1 - UP 189-2567 43 MAY 00
    1547 PT
    570 HP 2300 6BW1 - UP 189-2568 23 MAY 00
    1872 PT
    600 HP 2300 6BW1 - UP 189-2569 22 MAY 00
    1926 PT
    3196 MARINE
    340 HP 1800 2XR1 - UP 192-5345 2 MAY 00
    1190 PT
    385 HP 1800 2XR1 - UP 192-5346 1 MAY 00
    1348 PT
    450 HP 2100 2XR1 - UP 192-5347 48 MAY 00
    1477 PT
    490 HP 2300 2XR1 - UP 192-5348 45 MAY 00
    1618 PT
    570 HP 2300 2XR1 - UP 192-5349 42 MAY 00
    1871 PT
    600 HP 2300 2XR1 - UP 192-5350 44 MAY 00
    1972 PT
    660 HP 2300 2XR1 - UP 196-4393 38 JUL 00
    2165 PT
    3176C INDUSTRIAL
    310 HP 2100 2AW1 - UP 165-1741 17 SEP 98
    1008 PT
    325 HP 2100 2AW1 - UP 168-8830 32 DEC 98
    1200 PT
    365 HP 2100 2AW1 - UP 194-9706 20 MAY 00
    1000/1075/1165/1250/1325 PT
    365 HP 2100 2AW1 - UP 187-0840 24 JAN 00
    1165 PT
    400 HP 2100 2AW1 - UP 168-8832 49 MAR 99
    1281 PT
    3196 INDUSTRIAL
    420 HP 2100 1DW1 - UP 194-9707 18 MAY 00
    1200/1275/1350/1450/1575 PT
    C-10 UNDERGROUND MINING
    1008 PT
    250/270 MT 2100 2AW1 - UP 177-4902 36 MAY 99
    813/878 PT
    270 HP 2100 2AW1 - UP 159-5259 37 JUN 98
    878 PT
    310 HP 2100 2AW1 - UP 159-5261 38 JUN 98
    1008 PT
    335 HP 2100 2AW1 - UP 159-5263 39 JUN 98
    1089 PT
    3176C CLAAS COMBINE 480/485
    365 HP 2100 7ZR00269 - UP 196-2483 21 JUL 00
    1164 PT
    3176C R1700G LHD
    335 HP 2100 8XZ00001 - UP 191-1502 41 APR 00
    1008/1089 PT
    C-10/C-12 WITH AIR INLET SHUTOFF
    335 HP 1800/2100 3CS12000 - UP 195-9572 15 JUN 00
    1250 PT
    430 HP 1800/2100 2KS40000 - UP 196-3634 34 JUN 00
    1650 PT
    C-15/C-16 TRUCK ENGINE FLASH FILE CROSS REFERENCE
    Updated January 26, 2000
    australia
    Default c15-c16
    FIELD UPRATE ONLY
    C-15 (6NZ) HIGH HP ENGINE SERIAL NO. FLASH RELEASE
    RATING INFORMATION RANGE FILE IC DATE
    435HP 1550/1650PT 1800/2100RPM 6NZ00001 & UP 177-9192 75 NOV99
    435HP 1550/1650PT 1800/2100RPM 6NZ00001 & UP 177-9193 76 NOV99
    BRAKESAVER
    435/500HP 1550/1650 2100RPM 6NZ00001 & UP 177-9194 77 NOV99
    MULTITORQUE
    455HP 1550PT 2100RPM OR 6NZ00001 & UP 177-9196 79 NOV99
    1650PT 1800/2100RPM
    455HP 1550PT 2100RPM OR 6NZ00001 & UP 177-9197 80 NOV99
    1650PT 1800/2100RPM BRAKESAVER
    455HP MT 1550/1750PT 2100 RPM 6NZ00001 & UP 177-9198 81 NOV99
    455HP MT 1550/1750PT 2100 RPM 6NZ00001 & UP 177-9199 82 NOV99
    BRAKESAVER
    475HP 1650/1750PT 1800/2100RPM 6NZ00001 & UP 177-9200 6 NOV99
    475HP 1650/1750PT 1800/2100RPM 6NZ00001 & UP 177-9201 83 NOV99
    BRAKESAVER
    475/500HP 1650/1850PT 2100 RPM 6NZ00001 & UP 177-9202 84 NOV99
    TOP 2 GEAR MULTITORQUE
    475/500HP 1650/1850PT 2100 RPM 6NZ00001 & UP 177-9203 85 NOV99
    TOP 2 GEAR MULTITORQUE BRAKESAVER
    475/500HP 1650/1750PT 2100 RPM 6NZ00001 & UP 177-9204 86 NOV99
    475/500HP 1650/1750PT 2100 RPM 6NZ00001 & UP 177-9205 87 NOV99
    500HP 1650PT 2100RPM, 6NZ00001 & UP 177-9206 88 NOV99
    500HP FLEET 1750PT 2100RPM or
    435/500HP 1550/1650 OIL WELL SERVICE
    500HP 1650PT 2100RPM BRAKESAVER 6NZ00001 & UP 177-9207 89 NOV99
    OR 500HP FLEET 1750PT 2100RPM BRAKESAVER
    500HP 1850PT 1800/2100RPM 6NZ00001 & UP 188-7720 90 NOV99
    2300RPM TEL FIELD UPRATE ONLY
    500HP 1750/1850PT 2100 RPM 6NZ00001 & UP 177-9210 92 NOV99
    500HP 1750/1850PT 2100 RPM 6NZ00001 & UP 177-9211 93 NOV99
    500HP 1850PT 1800/2100RPM 6NZ00001 & UP 177-9212 94 NOV99
    500HP 1850PT 1800/2100RPM 6NZ00001 & UP 177-9213 95 NOV99
    BRAKESAVER
    500HP 1850PT 1800/2100RPM 6NZ00001 & UP 188-7721 91 NOV99
    BRAKESAVER 2300RPM TEL FIELD UPRATE ONLY
    550HP 1850PT 2100RPM 6NZ00001 & UP 177-9214 7 NOV99
    550HP 1850PT 2100RPM BRAKESAVER 6NZ00001 & UP 177-9215 96 NOV99
    550HP 1850PT 2100RPM 6NZ00001 & UP 188-7722 97 NOV99
    550HP 1850PT 2100RPM BRAKESAVER 6NZ00001 & UP 188-7723 98 NOV99
    C-16 (7CZ) ENGINE SERIAL NO. FLASH RELEASE
    575HP 1850PT 2100RPM 7CZ00001 & UP 177-9218 56 NOV99
    575HP 1850PT 2100RPM BRAKESAVER 7CZ00001 & UP 177-9219 99 NOV99
    575HP 1850PT 2100RPM 7CZ00001 & UP 177-9220 101 NOV99
    2300 RPM TEL FIELD UPRATE ONLY
    575HP 1850PT 2100RPM BRAKESAVER 7CZ00001 & UP 177-9221 100 NOV99
    575/600HP MT 1850/2050PT 2100RPM 7CZ00001 & UP 177-9222 102 NOV99
    575/600HP MT 1850/2050PT 2100RPM 7CZ00001 & UP 177-9223 103 NOV99
    BRAKESAVER
    600HP 2050PT 2100RPM 7CZ00001 & UP 177-9224 8 NOV99
    600HP 2050PT 2100RPM BRAKESAVER 7CZ00001 & UP 177-9225 104 NOV99
    600HP 2050PT 2100RPM 7CZ00001 & UP 177-9226 105 NOV99
    600HP 2050PT 2100RPM BRAKESAVER 7CZ00001 & UP 177-9227 106 NOV99
    Challenger 35/45/55 Flash File Cross Refere
  9. The Following User Says Thank You to 4hillbilly For This Useful Post:
    electricalcente (31st January, 2017)
  10. #9
    australia
    Default flash file c-16 2300=600hp
    trying to work how to up load . e mail me might be quicker
  11. #10
    australia
    Default c-16
    finley let me know what you want
  12. #11
    australia
    Default flash list
    well got there hope this help
  13. The Following User Says Thank You to 4hillbilly For This Useful Post:
  14. #12
    DK Veteran atetruckrepair's Avatar
    THE JUNGLE
    Default c7 acert flash file
    can anyone help me out with a file to turn this 250 hp c7 up i want to increase it to the highest it can go with the current engine configuration i do not want to change any hard parts sn# kal09039 i appreciate any help
    Thank's Bill
    __________________
    IF I WAS OF ANY HELP TO YOU PLEASE DON'T FORGET THE SCALES AND THANK'S BUTTON !!!!!
  15. #13
    Junior Member mmrj's Avatar
    Dec 2010
    right here
    Hope this helps .. should give you the flash file # you need..
    OTE: C7 "Hi HP Ratings" 250HP 800lbft to 330HP KAL1-12897 were factory built with
    Injector p/n 233-3535. If a "single" 233-3535 injector is replaced with a 241-3400
    injector w/seals (238-8091 p/n on injector... not serviced) then "all six" injectors
    MUST be updated to the same part number and the appropriate flash file and "etrim"
    files MUST be installed to match the "new" part number injector! Use list below to
    determine flash file based on installed injector number!
    S/N Range Injector P/N Date Code Interlock Flash F
    C7 KAL 250HP @ 2200 800 lb-ft ...* Important see note above for complete detail
    KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 7 247-4643
    Replaced 245-0834
    KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 41 300-0465
    Replaced 248-7641,251-7457,
    254-0999,259-5609,265-3334,272-5324,295-2333
    KAL12898-UP, SAP1-UP, WAX1-UP
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 41 300-0465
    C7 KAL 275HP 800 lb-ft ...* Important see note above for complete detail
    KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 8 247-4642
    Replaced 245-0835
    KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 42 300-0464
    Replaced 248-7640,251-7456,
    254-0998,259-5608,265-3333,272-5323,295-2332
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 42 300-0464
    8/26/2010 Page 213 of 237
    Copyright ?2006 - Mitchell Repair Information Company, LLC - All Rights Reserved.
    CARB (California Bus only) MAR04 IC 59 251-6210
    C7 KAL 275HP 860 lb-ft ...* Important see note above for complete detail
    KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 9 247-4640
    Replaced 245-0837
    KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 43 300-0462
    Replaced 248-7638,251-7454,
    254-0996,259-5606,265-3331,272-5321,295-2330
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 43 300-0462
    C7 KAL 300HP 800 lb-ft ...* Important see note above for complete detail
    KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 10 247-4638
    Replaced 245-0839
    KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 44 300-0460
    Replaced 248-7636,251-7452,
    254-0994,259-5604,265-3329,272-5319,295-2328
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 44 300-0460
    CARB (California Bus only) MAR04 IC 60 251-6209
    C7 KAL 300HP @ 2200 860 lb-ft ...* Important see note above for complete detail
    KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 11 247-4636
    Replaced 245-0841
    KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 45 300-0458
    Replaced 248-7634, 251-7450, 254-0992,259-5602,
    265-3326,272-5317,295-2326
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 45 300-0458
    C7 KAL 330HP 860 lb-ft (Truck) ...* Important see note above for complete detail
    KAL1-UP w/ "Field installed" 238-8091 Injectors SEP06 IC 53 300-0456
    Replaced 248-7645,251-7448,
    254-0990,259-5600,265-3323,272-5315,295-2324
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 53 300-0456
    *********************************** EMERGENCY RATINGS (ER) ************************
    S/N Range Injector P/N Date Code Interlock Flash Fi
    8/26/2010 Page 214 of 237
    C7 KAL 275HP 800 lb-ft (ER) ...* Important see note above for complete detail
    KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 12 247-464
    Replaced 245-0836
    KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 46 300-046
    Replaced 248-7639,251-7455,
    254-0997,259-5607,265-3332,272-5322,295-2331
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 46 300-046
    C7 KAL 275HP 860 lb-ft (ER) ...* Important see note above for complete detail
    KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 13 247-463
    Replaced 245-0838
    KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 47 300-046
    Replaced 248-7637,251-7453,
    254-0995,259-5605,265-3330,272-5320,295-2329
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 47 300-046
    C7 KAL 300HP 800 lb-ft (ER) ...* Important see note above for complete detail
    KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 14 247-463
    Replaced 245-0840
    KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 48 300-045
    Replaced 248-7635,251-7451,
    254-0993,259-5603,265-3327,272-5318,295-2327
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 48 300-045
    C7 KAL 300HP 860 lb-ft (ER) ...* Important see note above for complete detail
    KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 15 247-463
    Replaced 245-0842
    KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 49 300-045
    Replaced 248-7633,251-7449,
    254-0991,259-5601,265-3324,272-5316,295-2325
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 49 300-045
    C7 KAL 330HP 860 lb-ft (ER) ...* Important see note above for complete detail
    KAL 1 - 12897 w/ Factory installed 233-3535 Injectors APR04 IC 16 247-463
    Replaced 245-0843
    KAL1-12897 w/ "Field installed" 238-8091 Injectors SEP06 IC 50 300-045
    Replaced 248-7632,251-7447,
    254-0989,259-5599,265-3322,272-5314,295-2323
    8/26/2010 Page 215 of 237
    w/ "Factory installed" 238-8091 Injectors SEP06 IC 50 300-045
    C7 KAL 350HP @ 2400 RPM (ER) SEP06 IC 54 300-045
    Replaced 272-1428,298-7453
  16. #14
    Dec 2010
    right here
    I read in a differnt thread that you changed only 2 injectors, may make uprate difficult.. I would have posted my reply's in differnt threads only in here, but ran into this thread second.. sorry, not trying to stalk you..
  17. #15
    THE JUNGLE
    Quote Originally Posted by mmrj View Post
    no problem thank's for the info
    __________________
