Results 16 to 30 of 39
  1. #16
    Quote Originally Posted by eddie8 View Post
    What do you mean the whole package?
    just use what i posted...its all you need...you wanna spend more oney for niotihgn but bells and whistles that do nithgn then spend it...but i use it weekely without one issue...thats what i mean
  2. #17
    Quote Originally Posted by uhaulkid View Post
    I see what you posted and I didnt spend anymore money as I already have the program....but you didnt answer the question...bells and whistles?.....I got news for you...the software "might " be free here on this site but not on the Nissan site and the cal files are not. If one doesnt have the software then he's not getting the cal files. For a newbie that goes to that site he will have to pay for the software to get the cal files. If they (Nissan)didnt charge for the software then they wouldnt have put it on there site for sale.....right?
  3. #18
    if you knew where to look you would find the file i posted here that i found right on nisisans site where it is still posted. if you knew where to look if you have a sub to there tec site etc etc. i did answer your questions...bells and whitels...things you dont need. and like i said it done come with cal files only one oem does that free and thats kia and hyidna and thats cause they are ran service wise by same oem. other then that flash ablty for all us built cars is FREE that file is from nissian, open it see it..its there file. its a stripped down version of what you can go spend money on. if you had the program then why post about it? duhhh thats stupid. i gave you what nissian gives to everyone for free. if you want the paid version that does the ame hing fine....being auto instructor and my area is diag computers and flshing i have great knowladge of it in all makes model....but once again never said cal file srae free just the proggy....even said cal files have to be paid for read....also did ansser your questions with bells and whisltes....you asked to be able to flash nissins i ave you what you need mnus flash files which i said isnt free.....gotta go im driving 90 mph down the freeway on a phone typi ng this....you got what you need...its free from nissian....dl it use it get yur ecu number check for update via tsb..pay 20 bucks for file and flash it,....done gtta go bud good luck
  4. #19
    kuwait
    hi
    thanx for nisssanNERs Software
  5. #20
    Ok whatever you say.......
  6. #21
    Usa
    Nissan_J2534 file is not the NERS file, dont get confused.
  7. #22
    Need help guys, i have the subscription and the Nissan -J2534 software installed. It shows a CSV file error and goes off. Meanwhile the ECU number is 23710-ZH44A which i could also not find in the check list of ECU numbers. Need help guys, cheers.
    Car is Nissan Armada, 2006MY
    Sent from iPhone 4S
  8. #23
    Quote Originally Posted by sogaro View Post
    Im thinkin there isnt an update for this pcm
  9. #24
    Well its got the fault code C1179 which requires a reflashing to be fixed. Can a cloned Consult 2 or 3 be used to fix this issue? Can i flash online with a cloned Consult tool?
    Sent from iPhone 4S
  10. #25
    Thats an abs code. U need factory tool for that. Jbox will not work
  11. #26
    Thats a good question. Maybe somebody else can answer that one
  12. #27
    I had that same issue and found out with a jbox that all you can flash is pcm/tcm. It wont due abs
  13. #28
    if yu can flash ecu with it then yes, the tools knows not clone or not, if it works to flash then it works to flash. i have both and both are clones and both flash all ecus that can be done. its matter the good o rbad tool you have. if it works then it works if it does not then it wont work at all but that is the tool to use to flash ecu's with i do it daily. it may be your tools that giving you error..clones sometimes not so good?
  14. #29
    Now, i get things clearer. Eddie is right 100%, J2534 tools flash only Nissan ECU and TCM and Consults do both and other modules, for this job, its the Consult that has it. My Cardaq Plus is Ori not a clone. Uhaulkid , thx for the Clone bit, i know what to look out for
    Sent from iPhone 4S
  15. #30
    Sep 2012
    Default Ners and cardaq
    Not sure if this is the right place to post.
    Is any one having issues flashing with Ners software and cardaq ? Tried flashing a 350z wouldn't flash. Heard through the masses that GM MDI will work.
