Results 1 to 8 of 8
    Top Poster viliukas's Avatar
    Dec 2010
    Default mercedes w169 problem with esp
    Hello.i have the problem with mercedes a class w169 years.the problem is with esp,i scan it with autoboss v30 and found two DTC: 9000 control unit N80(steering column module is defective) and 9353 steering angle sensor overflow).The second fault erased,but the first-no.The car was after accident,i repaired airbags,so i should take off steering wheel and this module,but i think i collect everything ok and carefull.I want know or this problem could cause,for example:brake switch and my autoboss see just that N80 module as a faulty?Maybe you could suggest what to check?In the dashboard is lighting check endine indicator,but in the engine block isn't no one fault.or esp fault could cause check engine lightining?
    Excuse me for my english.
    Best regards.
    workshop
    check actual value
    turn stering rigth and left and can you see
  3. The Following 2 Users Say Thank You to mercis For This Useful Post:
    ASCM (30th May, 2020), davinci86 (1st March, 2019)
    Dec 2010
    Quote Originally Posted by mercis View Post
    check actual value
    maybe you where i could find it in autoboss because i use it the first time.so if i will that actual value is changing when i turn steering wheel,so everything should be ok with this module?i called my friend,he work with MB,so he said to look abs,esp fuses,lights,brake pedal switch...
    Default re
    check steering angle sensor value, maybe the steering sensor is mispositioned
    go to actual value in the steering module and there you can find actual value of the steering sensor
    Dec 2010
    Quote Originally Posted by tech111 View Post
    or if it wouldn't be right,i could it to adapt or set to the right position with autoboss?
    Portugal
    Hi!!
    I?m with a similar problem in a W169, it gives me always 0 degrees and don?t accept calibration. It appears after replace steering box.
    DK Veteran Artilect's Avatar
    EU
    I have same problem. When you start the car all OK. After 10min drive ABS light appears. At the ABS module I get the DTC about the steering wheel.
    On live data, the value of steering wheel is OK, and at 0? its straight aligned, all seems to be OK.
    Its seems to be some bad joint or contacts at angle sensor, or something like that. Has anybody have similar case. An can help me out.
    BR
    __________________
    If You Like My Post
    Please use the button on the LEFT side and the button on the RIGHT side.
    Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
    DK Veteran ASCM's Avatar
    Oct 2018
    Quote Originally Posted by Artilect View Post
    BR
    I have the same problem w169 does anyone know
    How to repair that problem
    Sent from my SM-J415F using Tapatalk
