HI
I just got my VAG-COM interface 10.6
but when I wanted to try the interface I have this problem
port status : ok
interface:found
type:ross-tech HEX-USB
Status: not plugged into car
THANKS
HI
port status : ok
interface:found
THANKS
Where did you get it from, is it original, if so contact Ross-Tech. If you look at the top of the word doc it got:
VCDS Beta 912.0:
Also check you have +12 on pin 16 and -12 earth on pin 4 of your cars DLC
Well it maybe a stupid question but was it plugged into the car with the ignition turned on?
If its a genuine Ross-Tech lead there is a green led that lights up when its plugged in without been plugged into the laptop showing its been powered.![]()
Keith
2010 Golf GTD (170)
I received my cable from china
I tried several car
ignition on
