I need it who have it ?![]()
I'll use the search button for you, going to cost you a Thanks tho.
http://www.digital-kaos.co.uk/forums...76/index9.html
post #121 and you can use DOC KeyGen or crack is posted toward the bottom of the page, post #131.
Also did you get your Allison adapter? What did you get?
I will buy Nexiq USB-Link do you know it ?
anybody have 2010 Allison TCM Reflash Software ?
usb link works well in allison,dpa 4 from deraborn.co is based software for allison and post the code ,someone will help you with that.
the life is easy... people complicate!!!!!!!!
life is funny just step away of people that wants make your life a shixx
http://youtu.be/PEw3nYmpEys
Did every thing on keygrace displays level 15 in left corner. Problem is when i want to write to tcu.
Clic on Write cal. clic on calibration file i have downloaded from other truck's tcu. Load the 530015W006G J07 file. Clic on open and error message is displayed (no key installed).
Can you maybe help me.
Found problem .
Cal file must be in same file as Keygrace mod file.
Please, can you give details ?
Hello, I have problem with Allison transmission Tcm Programming in order to copy calibration from one TCM and write it to Other TCM. both of them are A43. in order this action I used Allison TCM Reflash (read and write TCM, Winrw32),after writing calibration, every things is fine but when i check both TCM calibration with Allison DOC, all of things are same except current gear condition, the main TCM shows in Neutral condition but the other TCM which I wrote calibration, Shows question sing (??) and finally it didn't work for truck, I wonder that why this problem happened, all Parameters Are same between these two TCM Except current gear condition and I'm sure about that for first start the current gear should be in neutral for run engine, I'll Appreciate it if some one help me about this problem and let me have your suggestion for find a solution.
