Results 1 to 7 of 7
Hybrid View
    Dec 2010
    Default Multimeter showing random mV and mA is it normal?
    I got uni-t UT203 multimeter .When the probes are not connected to any thing, it shows random mV (AC & DC) and Random mA . Checked uni-t UT50C at maplins ,It does the same too.
    Is it normal ? ,I am hoping to buy UT50C and really like the rubbery feeling on it.
    thanks in advance
    racin-snake's Avatar
    Jun 2009
    hi i think this phenomena is called a ghost voltage
    check aes .com for a better description of this but yes its common on most dmm due to the fact they are so sensitive
    it also is a good indicator of an open circuit
    hope this helps a bit ...also you could try googling teslite ?
    http://www.aeswave.com/products/Product.asp?i=662
    as for the rubbery feel .....whatever pumps your nads mate
    Today is the Tomorrow you worried about yesterday ......Was it worth it ?
    Dec 2010
    Thanks guys I guess I will live with it, I cant believe I foocked my UT203 because of this. I thought it must be something short circuiting in side so I removed it and sprayed Electrical connector cleaner all over .Now the darn thing is worse than it used to be. I'm off to buy a new UT50C.
    Quote Originally Posted by racin-snake View Post
    LOL
    I was always told it was reading the magnatic force of the earth, but ghost voltage sounds good.
    Liteace's Avatar
    Mar 2009
    On a rock
    When you get your new one and it showing random mV hold the 2 probes together and it should show 0.00 or 0.01, then you know its OK
    Meat-Head's Avatar
    mains voltage 'in the air' near a socket is possable, meters on HT leads, go wappy
    There should be an adjuster pot inside.
    a meter CANNOT measure it's own voltage off it's battery.
    If you wish to destroy a meter 5000volts dc, does it, goes with a bang, usefull items for this type of voltage are, HF plastic welding machine or overhead projecter, hth meat.
    It is normal, as others have said. My Fluke does the same thing.
