Results 1 to 15 of 23
    alexics's Avatar
    Kidderminster
    Default Alpine MH9RN92T code
    I need a code from this dump out of a Renault Laguna.
    It does not matter how slowly you go so long as you do not stop - Confucious
    You will move very slowly when facing a brick wall - Alexics
    Ford Visteon V series LOCKED - SORTED
    Ford Visteon V series CODE OFF - SORTED
    Ford Visteon V series recoding - IN PROGRESS
    Ford Visteon V series calculator - IN PROGRESS
    VW Blaupunkt calculator - IN PROGRESS
    bonus2010's Avatar
    Scotland
    I've been following a conversation on another forum about this unit. It has been said that the code is not stored in memory in the changer, but in a separate unit stored elsewhere in the car.. (under a seat or in the boot) (part of the overall system maybe?)
    Your dump looks remarkably similar to what was posted (24C01). But, the code is stored in 24S32 elsewhere.....
    I'll PM you the forum addess link for you to look at, as it is against DK rules to post forum links of similar content to the board. ( may make more sense to you)
    cd changer MH9RN and head ?nit RENRAT the same codes
    head ?nit radio here..
    aissa09's Avatar
    Blida Algeria
    Default arik
    Good information thank you very much arik
    spain
    Good look arik thank you very much
    prusony's Avatar
    Belarus
    If blocks not married, "CABASSE" need two codes, one for the radio's , and one for the changer........
    The first code always asking radio!
    Sorry, let me enter this discussion:
    example:
    ALR92S40285
    020366
    8200089153 -- A
    PN
    MH9RN92S
    ALR92S31240285
    8200089153 T F714
    So, this sytem has 2 codes: 1 for RENAULT head unit and the 2nd one for Alpine CD Changer.
    The security number F714 is for Renault head unit and code F714=3179 would not work for Apline CD changer right?
    i.e. the code for Alpine head unit is calculated from Alpine serial: ALR92S31240285... right?
    Now tell me please, which code is required when you first time switch the radio after disconnecting a car battery for example?
    Also, I would appreciate if somebody could provide me with original serials and codes for Alpine CD changer units only:
    like this:
    ALR92S31240285=????
    alexics's Avatar
    Kidderminster
    I would hate to interfere with the creation of a new code calculator but I still need a code for this beast.
    Quote Originally Posted by alexics View Post
    I have the same information from another forum, code is stored in separate unit "elsewhere..."
    You will have a code and we will get the first good and original example of serial=code of Apine CD changer
    I've tried it
    changed, so
    how these algoritms??
    50 41 58 36 34 4b code:0000
    63 56 57 45 50 77 code ff
    Quote Originally Posted by ar***305;k View Post
    I've tried it
    changed, so
    What is the code for this dump?
    Rdecode
    prusony's Avatar
    Belarus
    Quote Originally Posted by Rdecode View Post
    Rdecode
    Try -= 0363 =-
  13. #13
    Quote Originally Posted by prusony View Post
    Try -= 0363 =-
    Rdecode
  14. #14
    alexics's Avatar
    Kidderminster
    Apparently there is a version 2 Renault calc and that is what should be used to calc the code. Only one person seems to have it.
  15. #15
    alexics's Avatar
    Kidderminster
    Thanks to all who helped. Solution found. I hope I remembered the thanks button for everyone. If not let me know.
