Hi!I created this hardrert, but can not find a code.
I'm trying toentium-mmx 200mhz win98.
setting:0-1999,i2c delay 10,15,30 Waiting time 1000,2000,4000
vwgamma 3 vwz6z3 2404+2404
What could be the problem?
Thanks in advanced!
Thanks in advanced!
to solve your problem it is necessary to program the 2 eeprom 24c04
simple but complicated
Thanks,yes I've read "Program for windows 98 works perfect,but
you have to use computer with max cpu speed 100MHz"
Then this is the problem(My old service computer 200 Mhz)?
(I push start, then i see 1,2,3,4,5...1999,but don't find code,about 1-2-3 hours.)
The simply and best tool for VW Philips Gamma 3 from http://www.atprog.boom.ru/Sindex.html (russian language)
Stan
it work for me on faster cpu you must load cass when program working display on the radio must blink everu time when new code is try i do it at list 5 radios without problems
you do waiting time max and when code is find casset in your radio will work for 2 seconds that means you must be present when program is working and the good thing is that this radio code is from 0000 - 1999 when the casset is runing you must stop program on button stop and you have code
I don't care how old the topic is. I chose the right one for me. I need it now
If you don't like it * close your eyes
--- Geros dienos ! ---
