Your local tuner can do it for you 100%!
Galletto 2012 v54 full with JTAG and Mini available
Big Stars never dies:
Colin McRae (1968 ***8211; 2007)
Richard Burns (1971 ***8211; 2005)
Georg Plasa (1960 - 2011
Here You are.
Pass in PM.
Some basic optimum map, which could add 15 HP to your engine, would cost 100+ eur, not to mention profi optimum or power remap! What you could expect from free remap?! I think only turbine blow off!
You aren't right!!!! The person has changed key parameters in the basic cards in a limit of the admissible!!! I know that I speak I study the chip tuning!! I approximately also rules! Instead of seeing result what for that that to tell!! Archive on the password!!! I do not know that you could suggest to change there 100 + eur! With the turbine all will be as it should be!! And to this man the big respect!
Sorry for my English
Who said that this remap isn't good?! Me or you? Look at post #5! I said that you can't expect good map for free! That's all!
it's more than true ... you can't expect to have a good remap by posting for a free file on a forum. It's simply not the way to go for it. I have said it many times in different posts. What if you receive a bad tune? Or you lock your ECU? Then go to the local tuner and he will solve the problem for few hundred euros. It would have been cheaper in the first place to go to him first time. Don't mess with ECU if you don't know 100% what you are doing and how to act if things go bad. You say you know what he modified ... but do you know the limit of your turbo or of injectors? Just asking ...
help pls i nedd a code to unlock my model
modelE161 pls
+1
Let's see if we can have a look to that wonderful file boomer received... On the other hand it's nice to have a public forum to learn how to test files with other people cars without any responsibility... nevre thinked of that way to do the thing, instead of buying my dyno and original equipment.
Password: vivaro99
Thanks for attention from the sharks chiptuning
I will explain! Look when created a theme and has what is the time passed! I that wanted that and have received (this file I have simply compared with my) as the man has made job that I have told to it thanks!!! In difference he didn't ask what that of money for the subsequent improvements in this file!! I didn't write that it tune file bad or good, I only have told that haven't received that expected in general from the chip tuning this car !!! And as a whole positive changes present !!!
Once again thanks!
P.S. It is not necessary to consider itself as the cleverest
