ok have you put firmware on let me no and i run throw it with you and have you up and runing in mins
Ive not updated it with any new firmware since I purchased it, put it this way it was working fine up till yesterday
If the box has worked before and your only getting FTA its an Internet issue.
With everything switched on "Modem, Router and the KV Box on a scrambled channe (Sports 1 is a good one)l" start with the modem, power off wait for 10 secs and power on, wait till fully booted and do the same with the router, when thats fully booted do the same with your KV box. Wait for a while without changing channels
ok you was lucky to get it loaded on delivery any he goes firstly go to menu and insterlation then sw up date .then do a factery rescan turn of router and box reboot ans scan as normal make sure inter net is working and all plug in let me no how you get on
Thanks for help Ive sorted it now just needed a SW update via main menu, cheers
Hi guys.
got the same problem. Cant do a sw update nothing happens.
It must be a internet problem. i have a wirless laptop through the router works no problem. Tried to reboot everthing but still the same only some fta channels.
HELP
check out the other threads mate, off for everyone
This games only about hardmen.
