Page 4 of 8 FirstFirst 12345678 LastLast
Results 46 to 60 of 107
  1. #46
    Quote Originally Posted by jfish View Post
    can you modify the checkhost function and use this code
    let me know the outcome
    yo mate
    with that code replaced, it doenst update at all, even if server is online, it just goes straight to error connecting to server
  2. #47
    Sep 2008
    Quote Originally Posted by rossi2000 View Post
    yo mate
    using the new code in the script, and my webserver down
    I get this
    Starting Updating the Channel List
    Detecting Dreambox Type
    DM500
    Enigma 1
    Please Waiting..Connecting to Server
    Connecting to kryten.dyndns.info[213.107.133.168]:80
    Error Connecting to Server
    with webserver up I get this
    DM500
    Enigma 1
    Connected to Server
    remotever.txt 100% |*****************************| 2 00:00 ETA
    No Update Of Channel Needed
    With ver.txt file missing from DM
    DM500
    Enigma 1
    Connected to Server
    Version File Missing - Reloading Channel List
    Downloading Latest Channel List For Sky Digital UK
    e1.bq.tar.gz 100% |*****************************| 43698 00:00 ETA
    Completed Downloading Latest Channel List
    Extracting Latest Channel List Enigma 1
    Copying Latest Channel List Enigma 1
    Completed Latest Channel List Enigma 1
    Please Wait...Refreshing Channel List
    +ok+okChannel List Refreshed
    with new version of bouquets
    DM500
    Enigma 1
    Connected to Server
    New Version of Channel List Found..Updating
    Process Complete
  3. #48
    Sep 2008
    if you have just downloaded the file I posted a few minustes ago, dont use this.. found a bug inside it and may cause some weird out of disk space error (not even sure why it happened) use this attached on
  4. #49
    ah no probs i'll have a look some moire
    on the new script, there are no commands to reload enigma2 bouquet + lamedb, they are needed and as follows:-
    wget -qO - http://127.0.0.1/web/servicelistreload?mode=1 <-- lamedb
    wget -qO - http://127.0.0.1/web/servicelistreload?mode=2<--- bouquets
    for the tar.gz creation
    i usually have my bouquets in enigma2 folder then i tar the folder up into enigma2.tar.gz
    what is the correct way to make a tar for your script? i know they are to be named e2.bq.tar.gz etc but what about inside the tar
  5. #50
    Sep 2008
    thanks will add the bit to reload on enigma 2 box (I dont have a DM800 to test on - unless someone can donate me one)
    I use IZArc to create the file, noticed using 7Zip the tar.gz file wasnt recognised by the DM500.
  6. #51
    i can test its np heh
    i know about creating tars what i meant was
    inside the tar.gz do you just have bouquet files or a folder named bq and the files inside that? know what i mean?
  7. #52
    Sep 2008
    another update
    this includes function to reload engima 2 bouquets
  8. #53
    Sep 2008
    no I dont retain the folder structure, the files are in a flat format - the script just moves the correct files to the correct location
    I may look into having file structure within the tar.gz file and then moving the files/folders in one go - therefore not messing with moving individual files and probably make the code more efficient.
  9. #54
    ah cool thx
    also the e2 reload commands dont need the root:dreambox in there its just 127.0.0.1
  10. #55
    Aug 2011
    Smile
    @ Jfish
    U r a legend mate! I have been trying to setup a script like this to use in CSP for a good 12 months.
    Thankyou for your efforts
    Cheers
    Satsalot
  11. #56
    V.I.P. Member SGTFlipFlop's Avatar
    Scotland
    Finally got round to doing this and I'm lost.
    On a DM500 where does the file go? & where do you look to enable the update?
    Same questions as above but for a DM800
    Please help a script noob out
  12. #57
    Sep 2010
    Quote Originally Posted by SGTFlipFlop View Post
    the best two people i can think for you to have a word with would be rossi2000 of DBUK or DIGIDUDE of the DW forum.
    or even give b16mcc a shout on DBUK.
  13. #58
    satsmo's Avatar
    Jun 2008
    There are plenty of peeps here that write those specific scripts.
    I refuse to answer that question on the grounds that I don't know the answer. - Douglas Adams
  14. #59
    Scotland
    I'm running rossi's script at the moment, But I like the idea of a checking script to see what is the latest bouquets
  15. #60
    Sep 2008
    if you mean where does the script go, you can place it anywhere on the dm .. I normally have it in /var/scripts on a dm500 and etc/scripts on a dm800
    to run the update, you can do it via a cronjob and run the script once a day or if you know how, incorporate it in an image.
