tar.gz file downloaded to dreambox but it remains at 0kb.
problem now fixed....see below
Reboot of everything.....
.....Now works !!!!
surly you could just host the a file in the addons section under settings there are sky uk settings available to download on there but they are from 2010 i think
So the script is 100% working , but may require a reboot for settings to take place ?
can anyone recommend a file host or a free webspace i can store my tar.gz i have tried many but box reboots and does not upload any channel list
hi guys i have been working all night to try get this working with the plugin script not the auto check one.
i have bought webspace and a domain name and i can successfullt download the tar.gz file through my browser to my computer etc but when i edit the web address to the script it does not load any channels can someone please tell me what the tar.gz file has to be name or even post a working channel bouquet list so i can upload it to my server and test if its my bouquet list at fault or not
any help will be much appreciated thankyou
PLEASE IGNORE ABOVE POST I DOWNLOADED FRESH SCRIPTS AND TRIED AGAIN AND ALL IS WELL
Have you had a look at free webs ? They offer a 100mb bandwidth on web accounts per month .
O e of the options is to make it dk specificthen you wouldn't go over the bw limit
Jo-jo pm me the details and I can have a look
i have it all working now thanks its pretty quick too am gonna have a crack at the auto check script later on now![]()
works well on my dm500-s but not on my dm7020 it does not load any bouquets at all and if i already have some it delete them all![]()
well i did have it working flawlessly went to bed for couple of hours tried again and its not installing the channel list again for some strange reason
arghhhh
it basicly now just deletes all settings rather than installing new settings
here is what i have done
have channel list bouquets (sgt flip flop)
rename the folder the files are in to enigma1
rar this folder up
convert with IZArc to .tar.gz
upload the .tar.gz to my web server
to test the fille is downloadable i type the webaddress into my browser and the file downloads perfectly
edit the Enigma1_Bouquet_Update_userscript.sh with my web address pointing to the .tar.gz file
upload both the sh and cfg file to var/tuxcom/plugins
chmod the sh file to 755
reboot box
when box returns
press yellow
select enigma1 bouquet update
i get executing blah blah
then another screen that says
exec+
box then reboots and return with any other settings i did have gone
this is exactly the same way i had it all working this morning and it worked great but now its now working for some strange reason
any help much appreciated
thanks in advance
i have also tried the auto check script and with a channel list installed through db edit after the time limit of 1 minute the script runs and deletes the channel list like it did do manually through plugins
i can not think what is wrong
Try these, I found hassle with a few rarring programs and the one I use works fine.
cheers will ftp them to the server now and try again
still the same with your tar.gz files mate
here is a copy of the log
+ BG=http://mywebsiteaddresshere/enigma1.tar.gz
+ cd /tmp/
+ wget
BusyBox v1.01 (2007.12.17-17:14+0000) multi-call binary
Usage: wget [-c|--continue] [-q|--quiet] [-O|--output-document file]
[--header 'header: value'] [-Y|--proxy on/off] [-P DIR] url
+ chmod 755 /tmp/enigma1.tar.gz
chmod: /tmp/enigma1.tar.gz: No such file or directory
+ tar -xzvf enigma1.tar.gz
tar: enigma1.tar.gz: No such file or directory
+ cd /tmp/enigma1
cd: 15: can't cd to /tmp/enigma1
+ rm -rf /var/etc/satellites.xml
+ mv /tmp/enigma1/satellites.xml /var/etc/
mv: unable to rename `/tmp/enigma1/satellites.xml': No such file or directory
+ cd /var/tuxbox/config/enigma/
+ rm -rf userbouquet.d79aa.tv
+ rm -rf userbouquet.db084.radio
+ rm -rf userbouquets.file.epl userbouquets.radio.epl userbouquets.tv.epl
+ rm -rf bouquets
+ rm -rf services
+ rm -rf services.locked
+ mv /tmp/enigma1/* /var/tuxbox/config/enigma/
mv: unable to rename `/tmp/enigma1/*': No such file or directory
+ rm -rf /tmp/enigma1
+ rm -rf /tmp/enigma1.tar.gz
+ reboot
This may stupid a stupid question, But have you editted the script file with your website address
as the log says :- + BG=http://mywebsiteaddresshere/enigma1.tar.gz
Not sure if you done that just to post on the forum
