Page 6 of 8 FirstFirst 12345678 LastLast
Results 76 to 90 of 107
  1. #76
    Quote Originally Posted by SGTFlipFlop View Post
    This may stupid a stupid question, But have you editted the script file with your website address
    as the log says :- + BG=http://mywebsiteaddresshere/enigma1.tar.gz
    Not sure if you done that just to post on the forum
    yes i just edited my webaddress out so no one has access it i put the text there to show this is where i put my web address
  2. #77
    i more thing when i downoad the file through a browser from my server it says downloading enigma1.tar.tar now i never noticed this before but it this normal ?
    the file is deffo called enigma1.tar.gz tho
  3. #78
    V.I.P. Member SGTFlipFlop's Avatar
    Scotland
    Just tested it on my DM500 and it worked no problems at all,
    Got 1 error about cannot find directory so inside the var directory created a folder called script, tried it again and worked fine.
  4. #79
    i have just trien the manual plugin way again and its downloaded the channel list fine this time jesus this is mind boggling good fun tho
    going to try the auto script again
    which script are yu using and is alls you have to edit the url ?
  5. #80
    Scotland
    I'm using a manual one by rossi posted earlier in this thread, Yellow button and choose
  6. #81
    ahh i have that working ok again now but the auto script is just deleting all settings rather than renewing them
  7. #82
    Scotland
    Post the auto update script here or in PM to me and ill have a look
  8. #83
    #!/bin/sh
    # script to download latest channels lists
    # Tested on Enigma 1 PLi Jade 3 images (DM500S)
    # Jfish 1 Feb 2011
    # change log
    # v1 - initial release
    # v1.1 - remove of reboot at the end of script - no need for it now
    # v1.2 - check for version update and only update if new version exists
    # v1.3 - added functions for copy routine - code easier to read and structured far better
    # v1.4 - check to see if local version exist, if not get channels list down and copy version file over
    # v1.5 - check to see if server is online before updating channel list
    # v1.6 - redirect output to NULL (disable screen output)
    # v1.7 - detect DM version and then perform necessary download for Enigma1 or Enigma2 image
    # v1.8 - Log of process written to /var/etc/refresh.txt - can be useful in debugging process
    # v1.9 - delete temp files created in /tmp folder
    dead=0
    dummyval=1
    box="UNDEFINED"
    etype=0
    ebq=""
    url="http://*********.co.uk/enigma1.tar.gz"
    date=`date -R`
    checkhost() {
    echo "Please Waiting..Connecting to Server"
    wget http://$url 2> /tmp/check.txt
    svr=`cat /tmp/check.txt`
    for i in $svr;
    do
         if [ $i = "Unable" ]
      then
       dead=1
      elif [ $i = "can't" ]
         then
       dead=1
      else
         dummyval=999
      fi
    done
    rm -rf /var/bin/index.html
    getfiles () {
    echo "Downloading Latest Channel List For Sky Digital UK"
    cd /tmp
    mkdir bq
    cd bq
    wget "http://$url/$ebq"
    echo "$date Successfully downloaded $ebq" >>  /var/etc/refresh.txt
    echo "Completed Downloading Latest Channel List"
    loade1 () {
    echo "$date Downloaded $ebq File From Host $url" >>  /var/etc/refresh.txt
    chmod 755 /tmp/bq/$ebq
    echo "Extracting Latest Channel List Enigma 1"
    tar -xzvf $ebq > /dev/null
    echo "Copying Latest Channel List Enigma 1"
    rm -rf /var/etc/satellites.xml
    mv /tmp/bq/satellites.xml /var/etc/
    cd /var/tuxbox/config/enigma/
    rm -rf *.tv
    rm -rf *.epl
    rm -rf *.radio
    rm -rf *bak
    rm -rf bouquets
    rm -rf services
    rm -rf services.locked
    mv /tmp/bq/* /var/tuxbox/config/enigma/
    rm -rf /tmp/bq
    rm -rf /var/tuxbox/config/enigma/$ebq
    echo "Completed Latest Channel List Enigma 1"
    loade2 () {
    echo "Extracting Latest Channel List Enigma 2"
    echo "Copying Latest Channel List Enigma 2"
    mv /tmp/bq/satellites.xml /etc/tuxbox/
    cd /etc/enigma2
    rm -rf *.tv
    rm -rf *.radio
    rm -rf blacklist
    rm -rf lamedb
    mv /tmp/bq/* /etc/enigma2
    rm -rf /tmp/bq
    rm -rf /etc/enigma2/$ebq
    echo "Completed Latest Channel List Enigma 2"
    reload () {
    echo "Please Wait...Refreshing Channel List"
    wget -qO - http://root:dreambox@127.0.0.1/cgi-bin/reloadSettings
    wget -qO - http://root:dreambox@127.0.0.1/cgi-b...adUserBouquets
    echo "Channel List Refreshed"
    echo "Process Complete"
    echo "$date Process Complete" >>  /var/etc/refresh.txt
    rm -rf /tmp/remotever.txt
    rm -rf /tmp/check.txt
    getverfile () {
    cd /tmp
    wget "http://$url/remotever.txt"
    chmod 666 /tmp/remotever.txt
    detectbox () {
    echo "Detecting Dreambox Type"
    if grep -qs DM500 /proc/bus/dreambox ; then
     box=DM500
     etype=1
    elif grep -qs DM7020 /proc/bus/dreambox ; then
     box=DM7020
     etype=1
    elif grep -qs DM600PVR /proc/bus/dreambox ; then
     box=DM600PVR
     etype=1
    elif grep -qs DM500PLUS /proc/bus/dreambox ; then
     box=DM500plus
     etype=1
    elif grep -qs 'dm8000' /proc/stb/info/model ; then
     box=DM8000HD
     etype=2
    elif grep -qs 'dm800' /proc/stb/info/model ; then
     box=DM800HD
     etype=2
    else
     box=UNDEFINED
     etype=0
    fi
    echo $box
    echo "$date $box and Enigma $etype Detected" >>  /var/etc/refresh.txt
    if [ $etype -eq 1 ]; then
         ebq="e1.bq.tar.gz"
    elif [ $etype -eq 2 ]; then
         ebq="e2.bq.tar.gz"
    elif [ $etype -eq 0 ]; then
       echo "Box Not Identified"
       echo "** ERROR Unable to Identify Dreambox Version ***"  >>  /var/etc/refresh.txt
       exit
    fi
    detectdm () {
    if [ -f "/proc/bus/dreambox" ]; then
     echo "Enigma 1 Image Found"
     box=`cat /proc/bus/dreambox | grep -i ^type`
     etype=1
     ebq="e1.bq.tar.gz"
    elif [ -f "/proc/stb/info/model" ]; then
      echo "Enigma 2 Image Found"
      box=`cat /proc/stb/info/model | grep -i ^type`
      etype=2
      ebq="e2.bq.tar.gz"
    else
      echo "This is not a Dreambox"
      exit
    fi
    echo "Starting Updating the Channel List"
    echo "$date Starting Update" >>  /var/etc/refresh.txt
    detectbox
    checkhost
    if [ $dead = 0 ]
    then
    echo "Connected to Server"
    echo "$date Successfully Connected to $url" >>  /var/etc/refresh.txt
      if [ ! -f "/var/etc/ver.txt" ]; then
      echo "Version File Missing - Reloading Channel List"
      getfiles
      loade1
      loade2
      fi
      getverfile
         mv /tmp/remotever.txt /var/etc/ver.txt
         chmod 666 /var/etc/ver.txt
      rm /tmp/check.txt
      echo "$date Version File Missing" >>  /var/etc/refresh.txt
      reload
         exit;
      fi
      getverfile
      localv=`cat /var/etc/ver.txt`
      remotev=`cat /tmp/remotever.txt`
      if [ $remotev -gt $localv ]; then
        echo "New Version of Channel List Found..Updating"
     getfiles
      loade1
      loade2
     fi
        rm -rf /var/etc/ver.txt
     echo "$date New Version Found" >>  /var/etc/refresh.txt
     reload
       else
         echo "No Update Of Channel Needed"
         echo "$date No Refresh Required" >>  /var/etc/refresh.txt
       exit;
      fi
     else
       echo "Error Connecting to Server"
       echo "$date *** Error Connecting To Server $url ***" >>  /var/etc/refresh.txt
    fi
  9. #84
    Jan 2012
    I can use this script to distribute the list of dm500 and dm800? as I do, I have nowhere to stay
  10. #85
    Jan 2012
    the script is running well.
    a suggestion for version 2.1 update to check the script itself if it occurred on the server update download and play it in the plugins folder.
    refresh.txt start from 0 after hitting a file size.
    congratulations
  11. #86
    Jan 2012
    Default thanks
    thanks to all for great work
    is it possible if it load auto on start up intead of pressing yellow button
    thanks in advance
  12. #87
    Apr 2011
    Hi, and great work guys.
    I'm having a few problems getting it going on my box though, using the most recent channelrefresh.rar script which was uploaded.
    Is there a newer version of the script available?
    I'm on a DM500, and can get the script to execute via the plugin menu, but it just deletes all my bouquets and reboots and I can't figure out what has gone wrong.
    Here is the contents of the log (refresh.txt)
    Fri, 10 Feb 2012 21:45:25 +0000 Starting Update
    Fri, 10 Feb 2012 21:45:25 +0000 DM500 and Enigma 1 Detected
    Fri, 10 Feb 2012 21:45:25 +0000 Successfully Connected to http://dl.dropbox.com/u/***removed_b...enigma1.tar.gz
    Fri, 10 Feb 2012 21:45:25 +0000 Successfully downloaded e1.bq.tar.gz
    Fri, 10 Feb 2012 21:45:25 +0000 Downloaded e1.bq.tar.gz File From Host http://dl.dropbox.com/u/***removed_b...enigma1.tar.gz
    Fri, 10 Feb 2012 21:45:25 +0000 New Version Found
    Fri, 10 Feb 2012 21:45:25 +0000 Process Complete
    Last edited by box2box999; 10th February, 2012 at 10:47 PM. Reason: added output log
  13. #88
    Apr 2011
    I have now fixed this - I did not have the bouquet files in a folder called enigma1 within the tar.gz
    Great Plugin - Thanks everyone
  14. #89
    V.I.P. Member 2tone's Avatar
    Jun 2008
    Would this work on a tm 500 or is part of the file sysytem different
  15. #90
    Jul 2008
    How would i change the script to upload cable bouquets and not sat ones?
    Ta.
