#!/bin/sh
# script to download latest channels lists
# Tested on Enigma 1 PLi Jade 3 images (DM500S)
# Jfish 1 Feb 2011
# change log
# v1 - initial release
# v1.1 - remove of reboot at the end of script - no need for it now
# v1.2 - check for version update and only update if new version exists
# v1.3 - added functions for copy routine - code easier to read and structured far better
# v1.4 - check to see if local version exist, if not get channels list down and copy version file over
# v1.5 - check to see if server is online before updating channel list
# v1.6 - redirect output to NULL (disable screen output)
# v1.7 - detect DM version and then perform necessary download for Enigma1 or Enigma2 image
# v1.8 - Log of process written to /var/etc/refresh.txt - can be useful in debugging process
# v1.9 - delete temp files created in /tmp folder
dead=0
dummyval=1
box="UNDEFINED"
etype=0
ebq=""
url="http://*********.co.uk/enigma1.tar.gz"
date=`date -R`
checkhost() {
echo "Please Waiting..Connecting to Server"
wget http://$url 2> /tmp/check.txt
svr=`cat /tmp/check.txt`
for i in $svr;
do
if [ $i = "Unable" ]
then
dead=1
elif [ $i = "can't" ]
then
dead=1
else
dummyval=999
fi
done
rm -rf /var/bin/index.html
getfiles () {
echo "Downloading Latest Channel List For Sky Digital UK"
cd /tmp
mkdir bq
cd bq
wget "http://$url/$ebq"
echo "$date Successfully downloaded $ebq" >> /var/etc/refresh.txt
echo "Completed Downloading Latest Channel List"
loade1 () {
echo "$date Downloaded $ebq File From Host $url" >> /var/etc/refresh.txt
chmod 755 /tmp/bq/$ebq
echo "Extracting Latest Channel List Enigma 1"
tar -xzvf $ebq > /dev/null
echo "Copying Latest Channel List Enigma 1"
rm -rf /var/etc/satellites.xml
mv /tmp/bq/satellites.xml /var/etc/
cd /var/tuxbox/config/enigma/
rm -rf *.tv
rm -rf *.epl
rm -rf *.radio
rm -rf *bak
rm -rf bouquets
rm -rf services
rm -rf services.locked
mv /tmp/bq/* /var/tuxbox/config/enigma/
rm -rf /tmp/bq
rm -rf /var/tuxbox/config/enigma/$ebq
echo "Completed Latest Channel List Enigma 1"
loade2 () {
echo "Extracting Latest Channel List Enigma 2"
echo "Copying Latest Channel List Enigma 2"
mv /tmp/bq/satellites.xml /etc/tuxbox/
cd /etc/enigma2
rm -rf *.tv
rm -rf *.radio
rm -rf blacklist
rm -rf lamedb
mv /tmp/bq/* /etc/enigma2
rm -rf /tmp/bq
rm -rf /etc/enigma2/$ebq
echo "Completed Latest Channel List Enigma 2"
reload () {
echo "Please Wait...Refreshing Channel List"
wget -qO - http://root:dreambox@127.0.0.1/cgi-bin/reloadSettings
wget -qO - http://root:dreambox@127.0.0.1/cgi-b...adUserBouquets
echo "Channel List Refreshed"
echo "Process Complete"
echo "$date Process Complete" >> /var/etc/refresh.txt
rm -rf /tmp/remotever.txt
rm -rf /tmp/check.txt
getverfile () {
cd /tmp
wget "http://$url/remotever.txt"
chmod 666 /tmp/remotever.txt
detectbox () {
echo "Detecting Dreambox Type"
if grep -qs DM500 /proc/bus/dreambox ; then
box=DM500
etype=1
elif grep -qs DM7020 /proc/bus/dreambox ; then
box=DM7020
etype=1
elif grep -qs DM600PVR /proc/bus/dreambox ; then
box=DM600PVR
etype=1
elif grep -qs DM500PLUS /proc/bus/dreambox ; then
box=DM500plus
etype=1
elif grep -qs 'dm8000' /proc/stb/info/model ; then
box=DM8000HD
etype=2
elif grep -qs 'dm800' /proc/stb/info/model ; then
box=DM800HD
etype=2
else
box=UNDEFINED
etype=0
fi
echo $box
echo "$date $box and Enigma $etype Detected" >> /var/etc/refresh.txt
if [ $etype -eq 1 ]; then
ebq="e1.bq.tar.gz"
elif [ $etype -eq 2 ]; then
ebq="e2.bq.tar.gz"
elif [ $etype -eq 0 ]; then
echo "Box Not Identified"
echo "** ERROR Unable to Identify Dreambox Version ***" >> /var/etc/refresh.txt
exit
fi
detectdm () {
if [ -f "/proc/bus/dreambox" ]; then
echo "Enigma 1 Image Found"
box=`cat /proc/bus/dreambox | grep -i ^type`
etype=1
ebq="e1.bq.tar.gz"
elif [ -f "/proc/stb/info/model" ]; then
echo "Enigma 2 Image Found"
box=`cat /proc/stb/info/model | grep -i ^type`
etype=2
ebq="e2.bq.tar.gz"
else
echo "This is not a Dreambox"
exit
fi
echo "Starting Updating the Channel List"
echo "$date Starting Update" >> /var/etc/refresh.txt
detectbox
checkhost
if [ $dead = 0 ]
then
echo "Connected to Server"
echo "$date Successfully Connected to $url" >> /var/etc/refresh.txt
if [ ! -f "/var/etc/ver.txt" ]; then
echo "Version File Missing - Reloading Channel List"
getfiles
loade1
loade2
fi
getverfile
mv /tmp/remotever.txt /var/etc/ver.txt
chmod 666 /var/etc/ver.txt
rm /tmp/check.txt
echo "$date Version File Missing" >> /var/etc/refresh.txt
reload
exit;
fi
getverfile
localv=`cat /var/etc/ver.txt`
remotev=`cat /tmp/remotever.txt`
if [ $remotev -gt $localv ]; then
echo "New Version of Channel List Found..Updating"
getfiles
loade1
loade2
fi
rm -rf /var/etc/ver.txt
echo "$date New Version Found" >> /var/etc/refresh.txt
reload
else
echo "No Update Of Channel Needed"
echo "$date No Refresh Required" >> /var/etc/refresh.txt
exit;
fi
else
echo "Error Connecting to Server"
echo "$date *** Error Connecting To Server $url ***" >> /var/etc/refresh.txt
fi
