Results 1 to 7 of 7
    Jul 2010
    dewsbury west yorkshire
    Default vectra cdr 2005 decode
    hi there can any1 remove the code from the file
    if that not possible can you let me knw the what is the code
    many thx
    aissa09's Avatar
    Blida Algeria
    Default ase
    try 8273
    Car235's Avatar
    Nov 2009
    Yes code is right
    Top Poster incar's Avatar
    May 2010
    UK
    Yes Code is right and i modified it to use without code, but You can do it by your self, just repeat code entering procedure on activated device.
    aissa09's Avatar
    Blida Algeria
    Default ase
    I did not understand
    laxitylabs's Avatar
    Jul 2010
    What do you not understand ? how to make code off?
    while you having working unit, you can induce code eneting once again by tp+as and then, if you will enter code again it will go code off !
    aissa09's Avatar
    Blida Algeria
    Default ase
    I understood thank friend good
