they do not have the file you are looking for but this is the latest file for that ecm number
here is the info
ecm software 271-1378
perf spec ok 5925
a/r# 260-2820
cor a/r 248 5546
oem e1j4r9b2d1aoac9j97
it is a c15 2006. 475. what can it be uprated to? does anybody have the file? am i going to have to load injector files for a uprate? any help would be very nice. I also need file 271-1378.
THANK YOU TO ALL FOR THE HELP HERE AT DK.
You can re-rate up to a 625hp 2050 tq max
What is that file for ? 475, 500 ? i did not look at it i just got it off of sis you may need injectors to get the power you are looking for and with the new injectors you will need trim files they new injectors usually come with a disk with the trim file on it sometimes you have to change hard parts like turbo, cam , etc you should call the local cat dealer and he will tell you what you need to do what does the tag on the engine say they usually say max hp rating of ??? whatever the engine can make usually i just go by that and it works fine
It can be flashed no prob...Cat says you need a piston,injector, and top turbo change because the engine will no way meet EPA spec with the added timing/fuel od the 625 flash in the 475 engine. Stock compression on a 475-550 ACERT is 18:1. The 600-625 factory engines are 15.2:1 or 16:1 cant remember which one.
