no need to virgin it , just go to coding in Developer mode and you all set ,
First off guys newbie here on this forum but not on mbworld.org. FLAME SUIT on!
Anyway I have a 2004 w211 E55 AMG that I want to swop a cluster on the a newer E63 cluster (old=white dials and new=black dials). So I know I have to get someone to do the KM+FLASH to get the mileage corrected but when I installed it in today I go 2 errors when I started the car.
1. PreSafe Warning deactivated
2. Speedtronic malfunction
I'm sure these are there due to the donor car having DISTRO PLUS. Can I disabled these using STAR Dev?
Will virginizing the cluster removed these warning? So I can then program the cluster like a new cluster.
ANY help is appreciated!
Try to found the eeprom 24c16 in your original dash from car
then read and SAVE eeprom
then open and found eeprom in another dash and
LOAD the dump what you save and write in.
Now you will have 2 same dash,
just put in car and it will work
I do it one before
hi mate just swap eeproms that will work
Milesbetteroff here to help
i dont think that the swap works . if the dashs dont have the same hardware, the dump of this eprom dont work and you say that dashs are diferent, in this car you can try to put the dash ans you can see if the dash works ok, if dont works ok you need a diag tool for reprogram the fuction for this car.the km are copy by the ezs it can pass in a few minutes .
So i got the PRESAFE warning taken care of but don't know where in DAS to set the SpeedTronic option for the dash cluster. Is this showing an issue as the drive authorization system is not authorized due to the cluster swop?
