Results 1 to 15 of 20
    Harrycz44
    Guest
    Default MB SPRINTER with GAlletto
    Hello I need help with pin outs from diagnostic socket to OBD2 galletto. Schema?? Thanks
    workshop
    Quote Originally Posted by Harrycz44 View Post
    wich software did you use?
    regards
    Harrycz44
    Guest
    Quote Originally Posted by sepistar View Post
    regards
    I want use Galletto
    Top Poster + ka-pa-za's Avatar
    Here you go.
    DK Veteran jovime's Avatar
    Nov 2010
    Chipland
    Post original here so we can tune it for free
    Harrycz44
    Guest
    Quote Originally Posted by jovime View Post
    Thanks all
    peko's Avatar
    on sprinter using galetto is dangeurous i think
    you risk "start error "
    which year your sprinter ?
    Harrycz44
    Guest
    I think year 1999
    peko's Avatar
    i think you risk start error, on edc15 better way remove flash and R/W directly on 29Fprogramor
    Harrycz44
    Guest
    Default Sprinter
    Hello friend here is it. Pleas look for it. Thank youuu
    netherlands
    Quote Originally Posted by peko View Post
    He is right about this. You can also take the eep 95p08 out and backup it.
    than write by obd.
    good luck.
  13. #13
    ALGERIA
    Exclamation
    good dump with egr off
    but there are very serious probleme in this dump that made the engine power very low
    so i let you serch where and i will anewer by yes or no
  14. #14
    ALGERIA
    exactly 50% of power of engine is lost in this dump
  15. #15
    Harrycz44
    Guest
    Hello It is original file... and I want tunned this..
