    Nov 2010
    Default VW Polo 2004 pin code
    Can someone please help me to read this dump and give me a pincode ??
    I got with silca & carprog PIN: 1262 but when i go to VCDS to enter login pin 01262 to imobilizer or instruments - it says wrong pin
    01262 VCDS doesnt want to accept.
    Also when i use silca - it says wrong pin (1262).
    Dash type: KOMBI + WEGFAHRSP VDO
    Part Num: 6Q0920840
    I want to add new key to the car.
    Can someone help me ?
  2. The Following User Says Thank You to znakedwrx For This Useful Post:
    mende (6th November, 2016)
  3. #2
    gokey's Avatar
    pin code is ok --- 1262
    Nov 2010
    Then i am doing something wrong to add new key. Can someone show me how to do add new key to this car? I have vcds.
    gokey's Avatar
    Go to 17 (dash), 08 (measuring blocks) and check group 24. There should be in all fields "0". If not, let ignition to be swiched on and wait untill all values become zero.
    Nov 2010
    Alex, you were right! I had to wait 10 minutes in order to punch pin code and to add new keys
    It worked just fine!
    Thanks a lot!
