zorans (15th January, 2020)
Reality of life :
1:Never argue with an idiot, he will pull you down to his level and overcome you with experience
2:Envy is the confession of inferiority
3:Everyone lies
How much trash you leave behind so much trash someone will have to read or maybe you yourself
If you like reading garbage, don't slow down, just speed it up
Also need immo off for test second ecu
Reality of life :
3:Everyone lies
hello there i have fiat ducato 2.8 jtd 2001 with bosch 0281 010 454. i want to swap used ecu i want to turn immo off i think i must right? and if im right where is immo stored in eeprom or flash ? what i need to read? any help please
here your answer............:
https://www.digital-kaos.co.uk/forum...10454-immo-off
need help
now my goal is to buy xp-005
who will help?
hello DK friends
can someone help with immo off for Ducato 2.8 . 0 281 010 486 . 29F400TC flash file attached .
thank you my friends
please add rep & thanks if my post was helpful
sparkle (19th March, 2020)
thank you RAFAL .
do I need to disconnect immo box ?
yes...................
need help
who will help?
sparkle (20th March, 2020)
Disconnected .... ....
A topic that interests me
hello guys. i have a project boxer with ecu 0 281 010 931 non start. i tried immo off file (flash 29f) from a good member and van start no problem. i use same file on a spare ecu and van starts no problem. i remove ecu for safe keeping and come back 4 weeks later and plug ecu and van dont start. Original ecu fuel pump primes and van dont start. Spare ecu fuel pump do not prime and van dont start. both ecu i wrote immo off file in flash and both worked and now 4 weeks later van dont start. immo box disconnected. the strange thing is that both ecu give different fault (one ecu fuel pump prime and spare ecu fuel pump dont prime). Both ecu same part numbers.
Can eeprom cause this problem. I never touched eeprom 5p
no, its not eeprom issue, you can make eeprom virgin only if MIL is on after start, or start and rev. The problem is in the VAN, not ECU, check fuel pump in tank
sagie1zn (13th April, 2020)
thanks for response guys, fuel pump is good, i used 12v probe to test. what make me suspect ecu file fault is that 2 ecu, same part number, from same type boxer, write same immo off file BUT one ecu make fuel pump prime with ignition on and other ecu no fuel pump prime with with ignition on. Both worked 4 weeks prior. i understand that it could be fault in van like maybe diesel or injector or wiring but like i say both ecu start the van and then 4 weeks later both ecu give different fault and both non start
Hello
Need to remove U1600 from Fiat Ducato 2.8,ecu is 0 281 010 931,anyone can do it?
Thank you ...
