Results 1 to 10 of 10
    Feb 2010
    Default Sprinter CDI injector replacement tech info
    Anyone have the service info on cdi injector R&R? Thanks
    florinyes's Avatar
    Dec 2009
    London Middlesex
    What you need to know mate?
    Apart from the pull it out grief it's all pretty straight forward..
    Intakes out, cover out etc...fit new washers and clamp bolts and off it goes.
    Whatever seems impossible is just not yet important enough.
    Junior Member nutsman's Avatar
    Mar 2010
    Liverpool
    Quote Originally Posted by talmadge View Post
    Depending on the year you may find that the lining of the top cover has melted, if so it will be all over the injectors and the allen bolts securing them. When this happens it will put hours on the job. If I remember correctly tighten sequence for clamp bolts is 7nm plus 90 degrees. Hopefully you wont have the problem with cover, good luck.
    Its not what's in your toolbox, its whats in your brainbox that counts.
    florinyes's Avatar
    Dec 2009
    London Middlesex
    Quote Originally Posted by nutsman View Post
    It's not the cover melted but carbon build from leaking injectors mate. Either way you'll need a tool to clean injector seat in head.
    Feb 2010
    Yea it took about 2hrs with a pick and pb blaster to get all the black carbon out, but injectors wont move ,scared I am going to break some think, I have ordered a tool from Hutson Precision.I was not sure I was doing it right. But after a little reading up Its called black death, its blow by and diesel.I guess a simple job is never simple.
    florinyes's Avatar
    Dec 2009
    London Middlesex
    Not on a CDI Merc mate
    Feb 2010
    Not on a CDI Merc mate.. What ??
    florinyes's Avatar
    Dec 2009
    London Middlesex
    Previous post edited..
    Jun 2010
    By the sounds of it you will need a good puller and seat cutter. Some can be stuck pretty well. You may even break the cam cover.
    Good luck.
    Andy
    Feb 2010
    Update :Tried to pry them out Tried to use a vice grips and wiggle them out soaked them for 24 hrs and used a slide hammer ordered a puller and cutter from hutson-precision-components like cutting butter, the only problem I ran in to after that, was one of the little I mean VERY VERY LITTLE steel balls dropped on the floor and went in to frairy tale land, had to buy one injector
