Results 1 to 5 of 5
Thread: gilinx.exe
    South Africa
    Default gilinx.exe
    Hi Guys
    I ve been infected with gilinx.exe
    It has created shortcuts of all my folders that does not exit
    i can see by looking at the size of the file that the data is still there.
    if i try rename it ,iam told the path or filename is incorrect or does not exist
    please advise if there is a remedy
    regards
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    i think thats malware, have you tried malwarebytes ? google it you will find it easy, ( update program before use )
    South Africa
    can effects be reversed ?
    South Africa
    Most important info I left out
    This is all happening on an external usb harddrive
    It has been suggested that I use attrib (dos cmd )
    I keep getting wrong parameters errors
    South Africa
    Default Solution to Gilinx virus
    As mentioned this virus changes folders to invalid shortcuts.
    I found a way to retrieve my data by using easy recovery software. I selected disk diagnostics and then size manager which allowed me to see that the data was still there , then copied it to a new location .easy
    thanks regards
