Page 1 of 2 12 LastLast
Results 1 to 15 of 16
    Top Poster partyzone's Avatar
    Jan 2009
    liverpool
    Default windows wont boot?
    tried turning on daughters laptop and gets error :-
    windows could not start because the following file is missing or corrupt:
    <windows root>\system32hal.dll.
    please reinstall a copy of the above file
    I have no idea what this is , but i have a copy of windows 7 on my own laptops external harddrive can i reinstall it from this?
    thx
    daz
    DK Veteran chucklor's Avatar
    Jun 2009
    notts
    Try system restore first, by starting the system up in safe mode(start computor up press f8,scroll to safe mode and press enter, then system restore to an earlier date) because if you are not doing a upgrade you will wipe out everything on the lappy, also if you decide to put win 7 in check whether the lappy you are going to install it on is compatable ie; enough HD and ram...
    Jan 2009
    liverpool
    thx m8, but cant even get system restore
    Jun 2009
    notts
    Can you start it up in safe mode?
    Jan 2009
    liverpool
    no just get that error, tried with all the f buttons and nothing happens x cept bios screen
    Jun 2009
    notts
    what operating system is on the laptop XP, Vista, win7?
    Jan 2009
    liverpool
    it was win7
    Jun 2009
    notts
    I think you should be able to use your copy and opt for the repair option on installation but they may be a simpler solution,
    Jun 2009
    notts
    V.I.P. Member allycoops's Avatar
    Feb 2008
    Behind Enemy Lines
    What are the system recovery options in Windows 7?
    If your computer's system is severely damaged and you can't access the System Recovery Options menu on your computer, you can access it using the Windows 7 installation disc or a USB flash drive, or using a system repair disc if you created one earlier.
    To use this method, you need to restart (boot) your computer using the disc or USB flash drive.
    Insert the Windows 7 installation disc or USB flash drive, or a system repair disc, and then shut down your computer.
    Restart your computer using the computer's power button.
    When prompted, press any key, and then follow the instructions that appear.
    On the Install Windows page, or on the System Recovery Options page, choose your language and other preferences, and then click Next.
    If neither the Install Windows page nor the System Recovery Options page appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start your computer from a Windows 7 installation disc or USB flash drive.
    If you are using the Windows installation disc or USB flash drive, click Repair your computer.
    Select the Windows installation you want to repair, and then click Next.
    On the System Recovery Options menu, click a tool to open it.
    Let the others come after us, We welcome the chase
  11. #11
    Jan 2009
    liverpool
    its on a notebook, can i re - install a copy of windows from an sd card?
    as no cd drive
  12. #12
    V.I.P. Member Fergal's Avatar
    Aug 2008
    what make and model is it?
    see if there is a recovery option on bootup like pressing F2 or something as it might have the recovery files on a hidden partion on the hd
  13. #13
    Feb 2008
    Behind Enemy Lines
    No, you need to make a bootable USB drive with windows 7 on,or if the windows 7 is genuine on the netbook? are you sure there is not a hidden partition with win 7 on it which you will be able to boot to and reinstall or repair
    What make and model is the netbook?
  14. #14
    Feb 2011
    can you use safe mode with command line?
    you could also try hiren bootcd?
  15. #15
    Member dave2014's Avatar
    Oct 2008
    If you stil havent resolved problem take a good read of this page and follow instructions, it guides you through every process of creating your bootable usb recovery drive. You will need to use another pc for the setup of the bootable usb drive. There are links on the page to all required files. Hope this helps
    Windows Wont Load? Use a System Repair Disc/USB Drive to Fix Your PC | Windows 7 Maintenance | Windows Tools, Help & Guides
