No problem for me with V5 or V8 version, they work perfectly.
Best regards
Best regards
Original Kwp2000+ and other...
No stress for all !
i have 1 like this with can fault, i have changed all parts except pcb, so in my case the pcb was faulty
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
I'll post here a version of software that came in a china clone
I'm glad to help.
thanks to all and not be held responsible for damage caused apologize for my English.
if it helps to make a patch for older versions also thank.
Link (MPPS V5.0.1.10.rar)
I have a funny problem.
MPPS tool - version 5.0.1.10
Hardware version - 6.01
Everything seems okay, the version information dialog does NOT say 'this is a clone'.
However ID/READ/Write buttons permanently disabled.
Anyone seen this behaviour?
Cracking stuff, sounds like a driver issue.
I did actually have problems installing the driver, first two attempts it failed.
Is there a place where the driver can be found seperately from the software? (I don't want to brick it).
PS thanks on the way for you.
yes sure,
here they are: MEGAUPLOAD - The leading online storage and file delivery service
to be sure it will work copy them in c:\windows\system32\drivers
and in device manager right click the interface and select update driver by choosing the driver in the specified address posted up
Thanks once again, I'm afraid it didn't work though.
(it's not plugged into a car in that screenshot but it behaves the same even if it is).
I think it could be a driver issue still, but to be honest the ones you sent installed perfectly.
you are getting older and older ... it took you a few days to see an obvious thing...
Dakta are you sure when you pug it into car you have +12? Check power suply on PCB. Do not foget- Its made in China! Regards
Yes it get's 12v, - fortunately it's made in romania (well it's a european version).
So I'm not sure, thanks though![]()
