Page 39 of 40 FirstFirst ... 2934353637383940 LastLast
Results 571 to 585 of 591
Thread: MPPS Repair
  1. #571
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Normally only one is wrong but check
  2. #572
    Sep 2018
    Thank you teerak2uk!!!!
    I conform:
    R13 = 47kohm 1% tolerance - correct
    / in my case was 4,7kohm (this is not correct). This is part of the voltage divider. Now after change of "fatal" R13 the voltage is correct. /
    I also change R7 = 4.7kohm. 1% tolerance
    and
    R8 = 120ohm /This is responsible for CAN connection and is NOT part of voltage divider, but is OK to be 1% tolerance 120ohm/
    This is the right way - first check the resistors!!!
  3. #573
    Sep 2018
    I conform:
    and
  4. #574
    Sep 2018
    Thanks to teerak2uk I have correct voltage with my MPPS V16, but same problem.
    I can NOT read my ECU.
    Please check the pictures and help my!
    Maybe it is necessary to change the firmware of my MPPS V16?
    And the problem is:
    Please help me
  5. #575
    Jan 2009
    I'm stuck with setupapi.dll error on windows 7. I tried downloading patch from page 16 but it says i don't have permission (in fact it says i'm not logged in no matter how many times i log in) even though i've already said hi in the appropriate sub forum.
    Help!
    EDIT sorry got it working by using the magic of the refresh button a few times
  6. #576
    Mar 2016
    Hello Friand, Merry Cristmas for all.
    I bricket blocked my v18 ,whith used software v21 , not reconize to pc . lock!! , you have file firmware to reflash Cf8051 ... , i not finded cf8051 flashed recange,if you have file , evalutaion to bay programmer.
    thanks for any response
  7. #577
    Lithuania
    I buy 2 programmers for C8051, no success. You can use Jlink, but it's difficult to find instructions how to read and write this chip with Jlink
  8. #578
    Mar 2012
    Hello all User im big Problem my Mpps China clone 5.1.10.
    Tool run Perfect many years,But from one Day to another,not have communication to the ECus.
    I have installed again software + patch 5.1.10 but nothing:-(
    I have my car flashed 20-30 everything run good,but now .....
    Gived solution for this problem,anything have same problems and have resolved?
    Thanks in advance
    Gived chance update my clone (flash)
    Anything have stuff for this.?
    Gesendet von iPhone mit Tapatalk
  9. #579
    Mar 2012
    Quote Originally Posted by moffo View Post
    Thanks in advance
    I have on this site upload pics...
    https://mhhauto.com/Thread-SMPS-MPPS?page=20
  10. #580
    Mar 2012
    Never can help me:-(
  11. #581
    Aug 2008
    think you are being abit too impatient
    only people that can help maybe not been on yet.
    you cant expect to ask for help and get it straight away, it may take days/weeks until someone comes that knows the answer
    also not good idea to post links to other forums
  12. #582
    Lithuania
    All china MPPS, new series too, working for 10-20 cars. You make 20-30, you a lucky man
    Buy new one and problem solved!!!
  13. #583
    Mar 2012
    Quote Originally Posted by tango View Post
    O.k sorry for post to another forum!!!
    The post from this tool can 20-30 flashes is not right .
  14. #584
    Jan 2016
    Hi all, i need help with a Opel EDC15M, i bought a MPPS 18 Clone and MPPS 16 Clone. There is no read out ID with K-line, no programm possible.
    Read ID only 0000000000, with both Interface MPPS 18 tested all so with V21 Software on Win 7, MPPS 16 with XP. Tested on car and with Tricore Adapter, Pin Out ist ok, Opcom and Tech2 can read the ECU. Tested on Opel Frontera and Isuzu DMax.
  15. #585
    Nov 2017
    hi. i have one MPPS v18 that dont make a ID, i try CAN and K-line but no luck, always says ecu not found, anyone know how to fix it?
    regards
