Page 24 of 40 FirstFirst ... 14192021222324252627282934 ... LastLast
Results 346 to 360 of 592
Thread: MPPS Repair
  1. #346
    Nov 2009
    Yes, mpps showed 12,6V
    I take the optican with the same voltage and its worked!
    What`s a print screen?
  2. #347
    Nov 2009
    Driver ist 6.0.1.0
    Date 17.11.2009
    Amt-Cartech Ltd
  3. #348
    bobolin4o's Avatar
    Apr 2010
    Bulgaria, V. Tarnovo
    Quote Originally Posted by lulu2003 View Post
    I've a done a tiny patch (needs .net 2.0) that removes the "NO READ" encryption of that version.
    Works fine for me!
    let me know.
    Patch already patched exe, or patch ori exe?
  4. #349
    Top Poster lulu2003's Avatar
    Jun 2011
    it was thought to be patching the patched from scary
    will check if it works vice versa or with (later) originals.
  5. #350
    bobolin4o's Avatar
    Apr 2010
    Procedure:
    1. Install MPPS V5.0.1.10
    2. Run Patch MPPS V5.0.1.10 Patch
    3. Put in the usb (from interface)and run FirmwareUpdate.Exe then MppsUpdate.exe
    4. Finaly interface works
    So, if i understand properly, at point 2, must use your patch, right?
    And it works with baned serial...
  6. #351
    DK Veteran mishu_b's Avatar
    Jul 2009
    Land of Choice!
    yes, correct
    atb
  7. #352
    DK Veteran lolooo1981's Avatar
    Feb 2011
    France
    Quote Originally Posted by bobolin4o View Post
    Procedure:
    Yes,
    For 234 and 236 serial this soft work good.
    Best regards
    Original Kwp2000+ and other...
    No stress for all !
  8. #353
    Jul 2009
    Land of Choice!
    @lo lo oo1981 - it is working for any serial. tested with nice results.
    atb
  9. #354
    Jul 2010
    Quote Originally Posted by bricolo View Post
    I just try and always with firmware : devise not found
    I've found on the net a C8051f340 to replace mine, i think i'll dont lost time and by this:
    MPPS 5.0.1.13 / 8.0.2.10 MCU Repair and update kit
    Thank for your help
    hi,
    how did you solved?have the same issue.have buy new mcu?or tryed something else.
    best regards
  10. #355
    Jul 2010
    so,no matter what i do,have no sn.anymoore it showed 0000000.think the interface are bricked.
    best regards
  11. #356
    ecutuners's Avatar
    Apr 2011
    United Kingdom
    Quote Originally Posted by sepistar View Post
    best regards
    Yes your mpps is bricked
    Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
    ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
    EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
    DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
    Professional Engine Software Development
  12. #357
    Multipla's Avatar
    Turin,Italia
    Default 4.0.19 prrrrrrrrrrrr?!!!!!
    I installed my mpps and put usb, open the folder, click mpps.exe and when open in video result error: 101 what is this error the operation I have do perfectly. I have a nootebook Toshiba whit XP and first is win7 but I dont like win7 and installed XP any help??? for mee. Tanksssssssssss
  13. #358
    Jul 2011
    Quote Originally Posted by scarymistake View Post
    And you have use the patch ????
    try to put it in C:\Multi Protocol Programming System
    ok thanks a will try it.
  14. #359
    Mar 2010
    My mpps show my good sn with 5.0.1.10 but i have problem with ecu not found k and can .Hou can i go back to 3.0.7???When i plug mpps with 3.0.7 sn is 00000
    Windows XpSp 3 mpps alu
  15. #360
    Jul 2009
    Land of Choice!
    A: you need to reflash with 3.0.2.7 dump.
    Q: I have a tool on my hands that shows when I'm trying to read ID to CAN - "Internal hardware error" - anyone else faced with such error?
    atb
