Results 1 to 1 of 1
    DK Veteran gmatj's Avatar
    Heaven (is place on earth)
    Default DAS & Xentry v2011.01 issues etc
    DAS & Xentry 2011.01 Installation, info, guides, issues etc
    Fellow DKers,
    I decided to open this thread to cater for all issues relating to DAS/Xentry version 2011.01
    I am sure you will all find a few issues relating to v2011.01 that would like to get fixed. Let us not mix them with all other versions.
    A few findings :
    (a) Mr Zolookas guide as found in
    http://www.digital-kaos.co.uk/forums/f152/updated-zolookas-guide-all-das-versions-164193/
    applies also to the new version
    (b) Also the fixes as found in
    http://www.digital-kaos.co.uk/forums/f152/new-xentry-awesome-solution-162517/
    also apply (use xe0911.exe does work)
    It has been said that from version 2011.01 DAS will not be directly available, only available through Xentry.
    Well you will be surprised to find out that if you copy all the shortcuts from previous versions those will work , and you will be able to run DAS directly. In the new installations only the shortcuts are missing.!!
    Please post new issues and/or old solutions to known ones for this new version.
    All the best to all of you
    G.
