Results 1 to 11 of 11
    Dec 2010
    Ukraine
    Default w140 start error
    Hi, friends
    I need help with w140 300td 1998. I have Start Error problem on this car. I tried to made new key with Gambit, but no luck. I dont have MB Star and did diag by X-431 and didnt have errors. I cant get actual dates for DAS and cant see whether the key is valid. What problems can I have?
    aliali18's Avatar
    tunis - (kasserine*Kairouan)
    Lightbulb
    Quote Originally Posted by Zaveruha View Post
    Hi, friends
    try Start Error ok
    Dec 2010
    Ukraine
    Quote Originally Posted by aliali18 View Post
    try Start Error ok
    TNX m8
    I will try tomorow. What soft are you use? Whether there was an error in my dumps?
    aliali18's Avatar
    Question
    TNX m8
    You worked ? ? ?
    Dec 2010
    Ukraine
    You worked ? ? ?
    Are you used ImmoKiler? I watched your immos file, and it has other type. I cant do keys new key for your file. It looks bad idea try to burn this dump to MCU.
    vanos batam's Avatar
    Batam-Indonesia
    you may try it...
    post result
    aliali18's Avatar
    pass pls !!!!!!!
    Dec 2010
    Ukraine
    Quote Originally Posted by vanos batam View Post
    you may try it...
    post result
    TNX for help, but your dump is similar with aliali18.
    barelang-kepri
    NO...
    The dump not same..
    Dec 2010
    Ukraine
    Quote Originally Posted by cardoctor View Post
    NO...
    The dump not same..
    No m8, is same.
    Dec 2010
    Ukraine
    Problem was in immo"s MCU. Replace immobox solved problem.
