Results 1 to 12 of 12
    i_shot_the_sheriff's Avatar
    Nov 2008
    Default Opel Corsa C Flash Memory
    Hello DKians,
    I just bought a KWP2000 and i just read the flash memory from my Opel Corsa C 1,0!!
    I got the file here.......
    Can anyone tinker it and make it more "economical" or something?
    Can it be done?
    I'm new to this field (chiptuning).... do you have any proposals on where to start studying??
    Nov 2008
    Also... do you know a better tool or a proffessional one to make this tuning by myself?
    Car manufacturers spend a lot of time mapping the engine.
    I doubt if you can make it any more economical.
    Unless you have a problem/defect in which case that should be fixed/repaired.
    ALGERIA
    yes,that's right
    the Car manufacturers programme the ecu to make it best economic
    the chiptuning let you have more power by more burning fuel
    so,what you ask for?
    the proffessional tool to make this tuning by your self is winols
    Nov 2008
    Ummm i didn't know that m8!!
    I thought that by tinkering that file you can make it more economical!!!
    Whats the original website for winols? I didn't find it! :P
    Thanks for the info by the way!
    ALGERIA
    use search buton to find winols in DK forum
    If you change the file without the help of professional tools - like a rolling road, a knock detection kit and exhaust gas analyzer - you can also destroy the engine.
    Nov 2008
    So..... it's not that simple huh??
    I guess i have to stick with the eprom reading only! :P
    Newbie supervizor's Avatar
    Romania
    Hi, I own a Corsa C 2006 Z10XEP, I have a Galetto 1260 and I could not read the file with this interface, you have any advice about this?
    I get this error when trying to read the map.
    Start data reading....errore SK1
    Errore sead key
    I tried and Z10XE and works perfectly.
    Moon
    Man, z10xep and z14xep are using ME7.6.1 which will never work by galletto. z10xe has a different ECU. For more details contact me in the romanian opel forum, or here by PM.
    Romania
    OK man, I know that have different computers for both work z10xe Motronic ME1.5.5 although the k-line, understand that they are so different, why can not connect to ME7.6.1 Galleto?
    Moon
    because ME7.6.1 it's not in the list of supported cars. to do it by OBD your safe choice is tech2
