I need pin for 1999 new beetle 1.9TDI
Thanks in advance
Thanks in advance
can i get pincode for this jeep from skim module year:2002
Jeep pin code: 1843 / 9523
I need pin for dump ECU eeprom 93C86 simos 7.1A
Simos 7.1A _93C86.rar
pin 26472CS: D1 E4 7A E1 A3 C8 00
pliplus (12th March, 2014)
hello need pin for citroen c4 citroen 95128.rar
What is it - CS: D1 E4 7A E1 A3 C8 00pin 26472CS: D1 E4 7A E1 A3 C8 00
[QUOTE = dyzio; 2249523] Ol? preciso pinos para Citroen C4 [attach] 249877 [/ attach] [/ QUOTE] HI m8
Vin: VF7RCRHRH76601398
Pin: LUCQ OR reverse
Cheers
Press "THANKS" button. just one click, CHEERS
dyzio (12th March, 2014)
hyundai accel 2006.rar
hi, i wonder if you can get the six digit pin code from the dump of a 2006 hyundai accel A/T 1.6, it is from a spi eeprom 95160 from a KEFICO PCM controller.
I have a hardware that supposedly gives the pin when last six vin digits are input, but the on it gives seems to be wrong, which is 522208, cars vin is KMHCM41C57U091721. the ecu has been replaced already and i don't know id the one who installed it before matched vin, that's why i im trying to find the pin number manually
thanks in advance
Hi,PIN by dump 102496
Thanks a lot, although I have typed already and I didn't succeeded, are you sure is that string? Have you used it? If that's so, to, then let me se what is the problem, do you know how to unblock the immo due to more than 3 times of wrong pin code? I think I already blocked it, theft light doesn't work any more
I apologize dude, the pin code you posted was right indeed, that fault is the ecu. Thanks a lot.
pin or immo off wv t4 acv 2.5 diesel bosch code hw is:0281001640 vag code is:074906021l please need help ecu engine is with 1 plug and alumunium case
Эй. Нужен Код штыря Nissan Primera P-12. спасибо заранее. EEPROM 93C66.
