Page 56 of 141 FirstFirst ... 646515253545556575859606166106 ... LastLast
Results 826 to 840 of 2104
  1. #826
    Mar 2013
    Patagonia Argentina
    Quote Originally Posted by kamel2003 View Post
    Need Pin from Dump
    95160
    BSI
    Peugeot 206 1.4
    Thank you
    i think is bad read, dont see any vin number.. pin maybe 7AKU - UKA7
  2. #827
    Dec 2010
    hello
    I need code pin from this dump boxer edc15c7 5p08
  3. #828
    DK Veteran zeljolaki's Avatar
    In my garage
    Hi!
    I need code pin from this dump: uzuki wagon r ,1999my,mitsubishi immo box,hitachi ecu..
    Tnx!
  4. #829
    qwertyuiop12's Avatar
    May 2013
    Quote Originally Posted by doudou241 View Post
    hello
    Hi,not pin code in this ECU.
  5. #830
    Nov 2012
    chile
    hola soy nuevo aca
  6. #831
    lkjubaking's Avatar
    Feb 2013
    Serbia
    Quote Originally Posted by lkjubaking View Post
    Friends have a problem
    Fiat Ducato 2.3mjet, 2008, EDC16 ECU died
    client got a second
    I just replaced eprom95640, turned on but not good to go and chek engine lamp flashes
    if someone can transfer pin from orig dump in the dump donor?
    SOLVED
    THANKS FOR NOTHING
  7. #832
    Feb 2014
    Hello
    I'm having problems getting the PIN for this Peugeot 307 202. BSI is with MC68HC912DG128.
    Can someone help me with the PIN, please?
    Here's the dump - HC912DG128.rar
  8. #833
    DK Veteran easternghost's Avatar
    Mar 2014
    hi try pin code E6EM
  9. The Following User Says Thank You to easternghost For This Useful Post:
    autoTkey (17th June, 2014)
  10. #834
    Feb 2014
    Quote Originally Posted by easternghost View Post
    Thanks! I also found it just now and it's the same as yours(E6EM), so it should be correct!
  11. #835
    Hi my friends could you please give me the pin code from VDO instrument cluster of Vw touran 2003? THANK YOU!!!
  12. #836
    nobody can help me?
  13. #837
    Top Poster skona's Avatar
    ON AIR-LANDING
    Default RENAULT UCH
    Could you give me please the pin code of Clio
    VFICR2T0H44138080
    Thanks in advance
  14. #838
    May 2013
    Hi,pin 16 42 71 C1 01 04
  15. #839
    Apr 2012
    Hello Skona can send fhoto the UCH
  16. #840
    DK Veteran elecautocr's Avatar
    Default Audi TT 1.8T PINCODE from Dashboard MC912DG128
    Hello members:
    I need to change the dashboard of Audi TT 2001 1.8T.
    Can you help me to find the pincodes ?? (for original and used dasboards )
    Thanks very much
