Page 82 of 142 FirstFirst ... 3272777879808182838485868792132 ... LastLast
Results 1,216 to 1,230 of 2122
  1. #1216
    doctore's Avatar
    Nov 2015
    Colorado Denver
    try pin 7636
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  2. The Following User Says Thank You to doctore For This Useful Post:
    fedas (30th December, 2016)
  3. #1217
    gokey's Avatar
    100%is good
    PUSH reputation and thanks If you think I helped .............................
  4. The Following User Says Thank You to gokey For This Useful Post:
  5. #1218
    Member fedas's Avatar
    Slovakia
    Thank you ! I'm goint to try it. I will let you know if it work.
    WORK PERFECT THANK YOU !
  6. #1219
    Top Poster FUSED:'s Avatar
    Apr 2016
    hi all,
    which machine to program renault key for cheaper?
    kind regards
  7. #1220
    May 2013
    nissan almera bcm sticker damage i need pin code from dump thanks in advance
    kwasi nissan almera 93c66.rar
  8. #1221
    Member korfi's Avatar
    Mar 2016
    Default toyota pincode
    hello thanks for help me this my dump for ecu immobilizer toyota yaris 2007
  9. #1222
    rola1971's Avatar
    Jun 2014
    Dublin
    Quote Originally Posted by korfi View Post
    it is immo boxs or ecu.you dont need pincode.you need key programmer.put this dump to any key programmer (tango,ade,tm100 ....) and make transporder
    try good luck
  10. The Following 2 Users Say Thank You to rola1971 For This Useful Post:
    doctore (4th January, 2017), korfi (4th January, 2017)
  11. #1223
    Mar 2016
    thanks rola 1971
  12. #1224
    Aug 2012
    New Zealand Quake central
    Default porsche 998
    Hi porsche immo M538, can someone please give me the pin code or immo off file for this also ecu 0261204605 eprom 24c04.
    Thanks.
    porsche.rar
  13. #1225
    Dec 2015
    Rafah, Palestine
    try pin code DA4C14
  14. #1226
    Nov 2015
    BusCan's Avatar
    Nov 2013
    Default Pin code
    Possible pin 5P08 PSA
    5p08 rene.rar
  16. #1228
    Jan 2017
    Can someone decode the pin code for Sharan II 2001 7M3920840G dashboard VDO V30.
    I tried Chinese vagtacho 3.01 but did not work. I want to learn on additional key via VCDS 16.8.4.
    Is the dashboard login code also the immobilizer login code for this "old" car?
    Immo is 7M3953257 and I still don't know if Immo 2 or Immo 3.
    Thanks.
    7M3920840G KOMBIINSTRUMENT VDO V30.rar
  17. #1229
    doctore's Avatar
    Nov 2015
    Colorado Denver
    true this Pin Code - 65535
  18. #1230
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by BusCan View Post
    5p08 rene.rar
    pin code KR48
  19. The Following User Says Thank You to doctore For This Useful Post:
    BusCan (19th January, 2017)
