Page 83 of 142 FirstFirst ... 3373787980818283848586878893133 ... LastLast
Results 1,231 to 1,245 of 2122
  1. #1231
    Jan 2017
    Are you sure on this, cause this is FFFF and is maximum possible number of the login code.
    I saw this with some of my tools but does not work. Is there another tool that could work?
  2. #1232
    Jan 2017
    Are you sure on this? It is just maximum number that is possible $FFFF.
    I saw this with some of my copied tools but does not work.
  3. #1233
    doctore's Avatar
    Nov 2015
    Colorado Denver
    from your dump i see this ,and maybi not good
    VIN 7M3920840GV3.0
    pin 65535
    Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
  4. The Following User Says Thank You to doctore For This Useful Post:
    mikajna (19th January, 2017)
  5. #1234
    mikajna's Avatar
    Mar 2015
    Quote Originally Posted by vagtacho View Post
    Can someone decode the pin code for Sharan II 2001 7M3920840G dashboard VDO V30.
    I tried Chinese vagtacho 3.01 but did not work. I want to learn on additional key via VCDS 16.8.4.
    Is the dashboard login code also the immobilizer login code for this "old" car?
    Immo is 7M3953257 and I still don't know if Immo 2 or Immo 3.
    Thanks.
    Attachment 422416
    Sharan does not have PIN code in cluster, you have separated IMMO box, its behind cluster...you can easily find him
  6. The Following 4 Users Say Thank You to mikajna For This Useful Post:
    Cesarec (30th January, 2017), doctore (19th January, 2017), rokibar (19th January, 2017), vagtacho (19th January, 2017)
  7. #1235
    Jan 2017
    Thanks a lot. That is perfect explanation why we all don't find it in cluster. Mileage I found already.
    Which tool could you recommend to dump immo EEPROM and find login without disassembling immo box?
    Or must I go the hard way with clamp and direct read out?
    Can I try vagtacho cracked v5.0 on my Chinese v3.01?
    I heard that it will destroy Chinese v3.01 hardware if Iwould try.
    Great forum and thanks!!!
  8. #1236
    doctore's Avatar
    Nov 2015
    Colorado Denver
    black immobox siemens remove and open use xprog or upa programmer
  9. The Following 3 Users Say Thank You to doctore For This Useful Post:
    Cesarec (30th January, 2017), mikajna (22nd January, 2017), vagtacho (19th January, 2017)
  10. #1237
    Jan 2017
    Bucharest
    would pe bossible to get VIn and PIN from this dash dump? (A3 2005 8P0-920-930 Q)
    (not sure if it's virgin or not) 8P0920930Q.zip
  11. #1238
    mikajna's Avatar
    Mar 2015
    You need to read eeprom directly, remove eeprom or with clamp, than make key with effi, transponder is ready to start car without changing eeprom content. Good luck, its 24C04 Valeo immo box if your transponder is ID44 as usual
  12. The Following 3 Users Say Thank You to mikajna For This Useful Post:
    Cesarec (30th January, 2017), doctore (23rd January, 2017), vagtacho (25th January, 2017)
  13. #1239
    Sep 2010
    hello
    please i need pin of this mitsubishi dump with 24c01
    regards
  14. #1240
    doctore's Avatar
    Nov 2015
    Colorado Denver
    Quote Originally Posted by large12390 View Post
    hello
    regards
    Pin Code - 1803
    24C01, 8pin, 128 Bytes
    Mitsubishi:
    Transponder Type: Blank PCF7936
  15. The Following 4 Users Say Thank You to doctore For This Useful Post:
    Cesarec (30th January, 2017), large12390 (22nd January, 2017), mikajna (24th January, 2017), rokibar (23rd January, 2017)
  16. #1241
    Jan 2017
    Bucharest
    Quote Originally Posted by TethiS View Post
    nobody?...
  17. #1242
    Apr 2011
    in lebanon
    nobody?...
    Hello.
    your request you can get it by obd2 not by dump.
  18. #1243
    Jul 2016
    hello can someone please help i need pin code for isuzu dmax delphi ecu part#8980173378
    eeprom 25lc320 many thanks in advance......
  19. #1244
    you need read 93c66 from antenna box.
  20. The Following User Says Thank You to stivencho For This Useful Post:
    ayussh (30th January, 2017)
  21. #1245
    Jul 2016
    sir stivencho can you please tell me where is the antenna box is located isuzu dmax and thank you so much for replying
