Page 43 of 142 FirstFirst ... 3338394041424344454647485393 ... LastLast
Results 631 to 645 of 2122
  1. #631
    Aug 2009
    Quote Originally Posted by gabigafu View Post
    your pin is D0 DE C7 FC DB 37
    Today I try it and one year later I tell you that works fine. Thank you very much.
  2. #632
    Dec 2008
    can someone please find PIN and CS from comfort module dump.
    Thanks in advance
  3. #633
    keygargoil's Avatar
    May 2010
    I need the ecu dump for decrypt the cs I can give you the pin from the dsump
  4. #634
    Quote Originally Posted by u.s View Post
    Thanks in advance
    Login: 21611
    VIN: WVWZZZ3CZCE084XXX
    Comp.: 34 A2 EC 38 9D C7 1E
  5. The Following User Says Thank You to autofan1965 For This Useful Post:
    u.s (4th November, 2013)
  6. #635
    Apr 2010
    I need PIN code from this dump *** Citroen C5 BSI dump ***
    VIN : VF7RCRFJF76775102
    95160.rar
  7. #636
    Moderator
    PremierD's Avatar
    Jun 2009
    YMRL or reversed.. funny dump mate .. but it should be correct
  8. The Following User Says Thank You to PremierD For This Useful Post:
    elna (5th November, 2013)
  9. #637
    Apr 2010
    Default Citroen C5 pin code
    Quote Originally Posted by PremierD View Post
    By Thanks...
    But i am tested YMRL , RLYM, YMB6, B6YM, B6RL, RLB6,... Do not mached
    I'm think pin code stored in another address of EEPROM.
    Please Help me
  10. #638
    qwertyuiop12's Avatar
    May 2013
    Quote Originally Posted by elna View Post
    By Thanks...
    Please Help me
    Hi,Try MYLR or read ECU and post dump
  11. The Following User Says Thank You to qwertyuiop12 For This Useful Post:
  12. #639
    Apr 2010
    HI, MYLR Do not mached...
    ECU is Mageneti marreli 6LPB , By ST10F280 Controler , do not have EEPROM or FLASH memory.
    my programmer not support st10f280
    Can you convert VF7RCRFJF76775102 to pin
    Please ...
  13. #640
    May 2013
    Sorry not convert VIN to PIN.The ECU must be eeprom 95160 or 95128.
    What year car? How many times have you tried to enter a PIN code, case no more than 3 times in a row?
  14. #641
    Jan 2012
    Poland
    95160.rar
    Try >>6BMY<<
  15. The Following User Says Thank You to pinn For This Useful Post:
    elna (9th November, 2013)
  16. #642
    Apr 2010
    Quote Originally Posted by pinn View Post
    Try >>6BMY<<
    THank you.
    code is accepted
  17. #643
    MOHCIN2's Avatar
    Feb 2013
    IN GOD'S EARTH
    Pin Code - 1703
  18. #644
    Aug 2013
    I need PIN code from this dump :Renault clio 2001 uch-bg
    93c66_ori.zip
  19. #645
    Apr 2010
    Quote Originally Posted by Thoom View Post
    93c66_ori.zip
    cant open your file
