Are you sure on this, cause this is FFFF and is maximum possible number of the login code.
I saw this with some of my tools but does not work. Is there another tool that could work?
Are you sure on this? It is just maximum number that is possible $FFFF.
I saw this with some of my copied tools but does not work.
from your dump i see this ,and maybi not good
VIN 7M3920840GV3.0
pin 65535
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
mikajna (19th January, 2017)
Thanks a lot. That is perfect explanation why we all don't find it in cluster. Mileage I found already.
Which tool could you recommend to dump immo EEPROM and find login without disassembling immo box?
Or must I go the hard way with clamp and direct read out?
Can I try vagtacho cracked v5.0 on my Chinese v3.01?
I heard that it will destroy Chinese v3.01 hardware if Iwould try.
Great forum and thanks!!!
black immobox siemens remove and open use xprog or upa programmer
would pe bossible to get VIn and PIN from this dash dump? (A3 2005 8P0-920-930 Q)
(not sure if it's virgin or not)8P0920930Q.zip
hello
please i need pin of this mitsubishi dump with 24c01
regards
Cesarec (30th January, 2017), large12390 (22nd January, 2017), mikajna (24th January, 2017), rokibar (23rd January, 2017)
hello can someone please help i need pin code for isuzu dmax delphi ecu part#8980173378
eeprom 25lc320 many thanks in advance......
you need read 93c66 from antenna box.
ayussh (30th January, 2017)
sir stivencho can you please tell me where is the antenna box is located isuzu dmax and thank you so much for replying
