Page 138 of 142 FirstFirst ... 3888128133134135136137138139140141142 LastLast
Results 2,056 to 2,070 of 2122
  1. #2056
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by pezao View Post
    Help pin code from dump
    MCU ID ??......
  2. The Following User Says Thank You to ricked For This Useful Post:
    pezao (9th September, 2023)
  3. #2057
    Apr 2012
    Default Thanks you
    thanks you
  4. #2058
    Apr 2012
    Default thanks you
    thanks you
  5. #2059
    ricked's Avatar
    Apr 2016
    Europe
    thanks you
    mcu id from flash file
  6. #2060
    Apr 2012
    Default Sorry
    Quote Originally Posted by ricked View Post
    Sorry
    Best Regards
  7. #2061
    Jan 2010
    First of all I don't know how to get dump... I have ELM32 and FES and MES only... My vehicle is Lancia Ypsilon from 2003/2004 with VIN number ZLA84300002026624 and I would like to get the electronic code couse I didn't get the Code Card when I bought the car...
    Can you guys help me somehow to get the code needed for unlocking some features?
    Thanks in advance... Best regards from Serbia
    Sent from my Redmi Note 9 Pro using Tapatalk
  8. #2062
    Apr 2022
    Germany
    Official dealer can give you PIN code from VIN. Here you will not get it…
    Other way is to remove immo box, read out motorla mcu, post eeprom dump here and you will get PIN code.
    MES and ELM 327 cannot help you to get the PIN code. For coding and diagnostics is MES really good…
    On your place I would recommend you to contact someone from west Europe, like Germany, send them VIN, pay about 25€ for code and that’s it.
    At official Fiat dealer in Germany you should get PIN code within 5 minutes.
    It is on a A4 paper and your contact can send you as photo per Viber/ What’s App…
    If you decide to try it with eeprom programmer, check first your immo box and mcu from motorola.
    After that you can, after good research,buy the right programmer…
    Regards to Serbia.
  9. The Following User Says Thank You to wuza For This Useful Post:
    alfini0507 (25th September, 2023)
  10. #2063
    Dec 2011
    Hi everyone . i need your help .I must generate pin immo micra k12 2004 from bcm eeprom 95160 .unfortunately number from glovebox disappeared.bcm nowy.rar
  11. #2064
    kiszka's Avatar
    Aug 2009
    please delete
    Reality of life :
    1:Never argue with an idiot, he will drag you down to his level and beat you with experience
    2:It’s hard to argue with a genius. It’s impossible to argue with an idiot
    3:Jealousy is a sign of inferiority
    4:Everyone lies
    How much rubbish you leave behind, so much rubbish someone will have to read, or maybe you yourself
    If you like to read garbage, don't slow down, just speed up
  12. #2065
    Nov 2023
    Hello plz help me from radio code magneti marelli
    MM-BTEL
    RNEG2 CEM00
    2013/05/05
    503551371010
    CD-8639
    SN* : 8MC0HE55E
    98067084xt
  13. #2066
    Sep 2009
    Lithuania
    Need pin for Nissan Titan, edc17cp51. VIN 1N6BA1F4XKN524510
    EEP like serial flash 25P16 ( 25P20 )
  14. #2067
    Nov 2023
    auto techniek's Avatar
    Mar 2017
    Need pincode from this JC bsi Citroen C4 picasso
  16. #2069
    Feb 2016
    Hi, I need a pin code from Corsa D CID eeprom Atmel AT25080 dump. Can anyone help?
  17. #2070
    Dec 2023
    06 cayenne siemens vdo 5wk47025 chip 93c86 ezp2023 eeprom
