Results 1 to 15 of 20
    Default w204 ezs problem
    hello
    any one please help me any idei to immo off on w204 ezs
    my problem is iggnition turn on & key turn but car not start esl motor soundnot come on
    here iattech ezs picture link
    if old ezs working or i buy esl also ?
    which tool is usefull for data read/ write for w204 ezs
    DK Veteran cleevesy's Avatar
    Abritus is probably your best bet to solve your problems ,you can read write ezs and esl with it, but its not cheap.
    MN005 Mercedes Key Programming Function - Mercedes - AVDI & COMMANDERS
    but i have w204 ezs nec is supported ?
    if launch x431 help to scan or i must mb star . when i install key message appear that " instalation key "
    Car starts straight from the starter motor but not from ignition switch..Das winging about ezs faulty
    my car c220 diesel automatic year 2008
    eprommazza's Avatar
    Quote Originally Posted by rinaprasant View Post
    check fuse ....
    professional chiptuning and electronic car repair...four-DynoRace_ wheel_ dynamometer
    i check all fuse is ok , when we enter key , stering lock motor not open ,
    Nov 2010
    stay on earth pls , immo off C 204 ??? , in dream maybe
    actualy most common problem for C 204 , no ignition
    is EVL , for year 2007
    solution :
    order from mb new EVl with orange key and learn EZS
    new EVI what meaning of this bcoz i dont understand ,
    is this power stering lock ?
    yes steering lock is problem
    so new esl work directly or coding with ezs & ecu
    please give me informanation
    the probleme in esl not in ezs
  13. #13
    Croatia
    You must exchange your steering lock, and it needs to be "married" with the car with a well known "orange key". Only a dealer can do it.
    Cheers
    If You want to thank me or some other forum member use the Thanks button.
  14. #14
    Top Poster + doaa's Avatar
    Mohammédia
    probleme in eslnot in ezs
  15. #15
    Be exactly!
    Does your engine running by shutting starter relay or what?
    Can you turn the Key in the ESZ?
    Otherwise problem can be ECU or CAN
    Check 50 line by Star. Tell us what DTCs have you got.
