Results 1 to 15 of 19
Thread: carsoftware
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    Default CarSoftware 5.0
    Here is working software. I make a thank to myself for finding original software and like always, thanks to EvOlUtIoN (SnD) for creating loader...
    Galletto 2012 v54 full with JTAG and Mini available
    Big Stars never dies:
    Colin McRae (1968 ***8211; 2007)
    Richard Burns (1971 ***8211; 2005)
    Georg Plasa (1960 - 2011
  2. The Following 3 Users Say Thank You to ipejasinovic For This Useful Post:
    just4upal (27th November, 2019), Meat-Head (5th March, 2014), tkumonryu (28th August, 2014)
  3. #2
    blackpirate's Avatar
    Jun 2009
    nice done! installer + .net framework+ loader!
    cheers
    If freedom is outlawed, only outlaws will have freedom!!!!
    Bulgaria
    How to remove 1.5.5? I must flash on obd with file from carsoftware?
    Bulgaria
    Hello, i try to reflash ecu with file from carsoftware 5.0 with immo off for Alfa 156 1.8 ts with m1.5.5 version 0 261 204 947-1037359649 but when i try to reflash i see message access denied.
    How to reflash? Where is the problem? I try with connected immo box and with disconnected. Tha car have problem with code reading from key. Code lamp is illuminated.
    How to immo off? I have ori dump file from eeprom.
    Feb 2011
    Egypt
    good job
    and anyone can help me if i want softwear for Opel cars or can have how i can get ID and Password to enter GM Global
    Default password
    Quote Originally Posted by ipejasinovic View Post
    hello,
    You can have the password for rar file?
    thanks in advance
    DottoreBL's Avatar
    Bosnia
    Koji kabal treba za ovo ?
    What interface do i need for this ?
    4f 54 54 4f 52 45 20 45 4c 45 43 54 52 4f 4e 49
    UAE(RAK)
    what exactly this software does?
  10. #9
    DK Veteran teuton's Avatar
    Mexico
    Quote Originally Posted by usman295 View Post
    basically it will allow you to alter Ecu dumps inorder to virginize or eliminate immo and to shut off the egr .
    Yesterday we stood in front of the abyss. Today we'll move ahead.
    If you need any repair manual, pm me- maybe I can help you.
  11. #10
    Spain
    Help: When I upload a file I get this.
    Thanks.
  12. #11
    Spain
    Default Error framework
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.IO.FileNotFoundException: Could not load file or assembly 'System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089' or one of its dependencies. El sistema no puede hallar el archivo especificado.
    File name: 'System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089'
    at CarSoftware.Home.elaborate()
    at CarSoftware.Home.Button1_Click_1(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    WRN: Assembly binding logging is turned OFF.
    To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
    Note: There is some performance penalty associated with assembly bind failure logging.
    To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Fra...7/mscorlib.dll
    CarSoftware
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Archivos%20de%20programa/...arSoftware.exe
    Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL...isualBasic.dll
    System
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL...089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL...dows.Forms.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL...em.Drawing.dll
    System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL...e.Remoting.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
  13. #12
    Spain
    Solved with these steps:
    1? step install Framework V2.
    2? step install Frameworkwork V3.5.
    3? step install Framework work V4
    But first I have uninstalled all versions of frameworck.
    Enjoy.
    Now it's good
  14. #13
    pinkfloyd5eg's Avatar
    DARK SIDE OF THE MOON
    hi friends, many thanks ipejasinovic
    great job ,just if possible ,can you edit the language of this software to convert commands and error messages into English ... is it possible ??
    << KEEP LEARNING W.O LIMITS >>
    2 Simple Methods To Say Thanks on DK
    Press Thanks _OR_ Add Rep
  15. #14
    ROBERTby2000's Avatar
    in electronics
    what`s new in carsoftware 5.2?
  16. #15
    antwnhszr's Avatar
    macedonia is greek....
    many thanks my friend I wish you to be always so, and to help as you can. Your job is very good.
