the background is the following: car arrived to remove the soot. 2008. removed the block, they saw that there were no EDC 16 and EDC17, put back, because equipment for reading the Flash was not. Cars moved out of boxing, worked for 1 minute and decayed.
Errors are as follows:
Address 01: Engine electronics Label: 03L-906-022-CBA.clb
Number of control unit: 03L 906 022 BL HW: 03L 907309
Component and / or Version: R4 2,0 L EDC G001SG 6221
Coding: 0050072
Code workshop: WSC 01346 995 97473
VCID: 70E42CD91ACB
4 Faults Found:
004997 - Defective control unit
P1385 - 000 - -
Freeze frame:
Status fault: 01100000
Priority Fault: 2
The frequency of failure: 1
Mileage: 183,030 km
Countdown: 0
Date: 2011.02.05
Time: 5:23:44
Freeze frame:
RPM: 0 / min
Speed: 0.0 km / h
Lambda: 2.4%
Abstentions. weight: 0.0 mg / ul
Voltage: 0.000 V
(No host): 0.0
Voltage: 3.300 V
001542 - Defective control unit
P0606 - 000 - -
Freeze frame:
Priority Fault: 2
Mileage: 183,030 km
Countdown: 0
Date: 2011.02.05
Time: 5:23:44
Freeze frame:
RPM: 0 / min
Speed: 0.0 km / h
Load: 0.0%
Torque: 0.0 Nm
Bin.bity: 00101001
Number of injection: 0.0 mg / ul
Temperature: 9.9 ? C
001576 - Relay electric fuel pump 1: Short to Ground
P0628 - 000 - - - Malfunction indicator ON
Freeze frame:
Status fault: 11100000
Priority Fault: 2
Mileage: 183,030 km
Countdown: 0
Date: 2011.02.05
Time: 5:23:44
Freeze frame:
RPM: 0 / min
Speed: 0.0 km / h
Voltage: 11.70 V
Pressure: 0.0 bar
Lambda: 15.0%
Lambda: 7.9%
009315 - Diesel Particle Filter: Excessive Soot Accumulation
P2463 - 000 - - - Malfunction indicator ON
Freeze frame:
Priority Fault: 2
Mileage: 183,030 km
Countdown: 0
Date: 2011.02.05
Time: 5:23:44
Freeze frame:
RPM: 0 / min
Speed: 0.0 km / h
Pressure: 0 mbar
Hex value: 0xFF01
Temperature: 6.0 ? C
(No host): 0.0
Mileage: 2550 km
Need help of any kind, I suspect that there was a pure accident and fell off the software part proshivy, but what and where these blocks is stored, I do not know. Than subtract Flash, Eeprom and processor?
In the presence of BDM 1255, but he seems to EDC 17 is not read.
The people, help the new unit under the order 2000 Euro, very painful.
We will be glad to help morally and financially
