hello
please password
I not interestet to a stand I have a stand but not for bosch pump
I can put a bosch pump on my stand but not to command
My interes is only for command the pump
At opel the engine is able to start without crankshaft sensor, the ecu enable the pump only with internal pump speed sensor
What is the information to send to pump via CAN to make it start
In this information is a sector for quantity
hello
please password
Sniffing can bus is the way to go It is possible to operate the pump with a simple can bus controller .
Method to record transmission is very easy you need two simply and cheap tool:
First: Clone of Salea Logic (less then 10 euro)
Second: Chippest CAN driver example: SN65HVD230 (symbolic amount
Another expensive logger are not reqired
"Everything what is around us, is doing by people for people"
tonyErre (14th September, 2023)
Deniss soft vp44 and others...
press thanks
adrianoo (24th January, 2020), amgcee (17th October, 2020), danours (10th March, 2019), daquima (27th March, 2019), desobg (21st August, 2023), diesel88 (16th September, 2023), dizelmester (21st October, 2021), Edishp (2nd June, 2023), ekam2 (17th April, 2018), extaller (22nd May, 2023), ftw666 (6th June, 2018), galiza (30th November, 2018), geos (7th August, 2022), Gferi (15th October, 2018), haidumartocian (22nd June, 2018), hum autobpic (22nd September, 2019), impolis (9th May, 2023), jurlak1 (8th September, 2018), Kicba (29th October, 2019), koruptx2 (16th September, 2018), kostelectronics (20th May, 2020), kuljitsall (6th December, 2023), loki954 (30th December, 2017), MarekP (16th October, 2022), mazi77 (11th December, 2023), mr10 (15th June, 2022), Orphanic (28th May, 2018), passat131 (12th March, 2023), pollito128 (26th April, 2018), puki (11th November, 2022), Pyromaniak (24th March, 2021), reini1976 (2nd June, 2022), Rider667 (21st September, 2022), robert1966 (22nd July, 2020), rolland (8th November, 2018), rui (25th February, 2018), shanektm450 (23rd October, 2021), skoulias (27th March, 2018), slavisac (28th February, 2021), snukis7 (21st December, 2021), taki (11th May, 2018), tonyErre (14th September, 2023), Trautec (2nd January, 2023), traxpalicaru (30th March, 2020), unimetal (3rd October, 2019), vvanka7a (20th July, 2021), yviood62 (1st February, 2024), zaycew (5th April, 2020)
Hi, dose someone try with FOCOM, or is not ok baud rate? i will try also with opcom and post some pictures.
Tried today with focom , get connection but only numbers as DTC s ,without definition of DTC .Also no measured values.Also tried Dennis and opcom ,opcom seem to be better but no actuator activation ,no measured values and most annoying no DTC even the car don t start ,someone said that DTC come only after long non start cranking.
Kind of useless tools ,I try to measure and check everything on module because of lack of hints and lately had a few failed repairs because I ve changed only transistor .
Hello ,please can I have the link for denis software vp44
Best regards.
Hi Decoco,
That linknot work for download software. Please upload another server and share the link. Thanks in advance.
I have same problem with my car. can you solved it? Thanks in advance
