Page 6 of 7 FirstFirst 1234567 LastLast
Results 76 to 90 of 104
  1. #76
    pinkfloyd5eg's Avatar
    DARK SIDE OF THE MOON
    Quote Originally Posted by ray978 View Post
    in the end I'm confused ..
    I use the old interface with new software without causing damage and without making changes?
    you are right mate, we are discussing how to use any loader software to upgrade firmware for other old interfaces that can't upgrade directly as yours or even those damaged or removed units can then try to program the PIC by USB connection only without needing a PIC programmer or connecting wires.
    Congratulations on your update
    << KEEP LEARNING W.O LIMITS >>
    2 Simple Methods To Say Thanks on DK
    Press Thanks _OR_ Add Rep
  2. #77
    DK Veteran mishu_b's Avatar
    Land of Choice!
    Quote Originally Posted by pinkfloyd5eg View Post
    hi mate, thanks for your reply, just a little note, be sure to select the right COM port as the virtual port of the interface driver... I am sure you would do that, but this just a reminder anyway.
    I have done this accordingly, of course, one of the loader written into FTDI some ugly info there, I needed to use MProg afterwards to revival the FTDI device.
    I'm still looking to see if it is possible to write fw into a empty PIC with these loaders!
    keep you in the loop!
  3. #78
    tiguan's Avatar
    Default Succeeded firmware to 1.39
    Quote Originally Posted by tiguan View Post
    Someone has given a Op_Com without software CD, I do not know whether it is original or clon (I think Clon)
    Just downloaded drivers to check with OPComFUT
    which version is the version it is a Firmare version 1.20
    Can someone help with my version of what I need to update and software that I can best use it.
    it is the first time in my Op-Com to use....Please Help...
    Tiguan
    Thank you all.....Succeeded firmware to 1.39
    Software Clon 08-2010 Multi....works well
    Many thanks to Marttydr67@
    Tiguan
  4. #79
    Default OP-COM Apps PDF
    hi again mates, I found those old PDF files for IMMO and Airbag coding applications using OP-COM software, may be many of us had them already, but anyway, here they are attached for all.
    good luck.
    Last edited by pinkfloyd5eg; 26th December, 2011 at 02:38 PM. Reason: removing PDF according to copyrights issue...
  5. #80
    Dec 2011
    is this a china software?
  6. #81
    Ashraf6119's Avatar
    UK
    good luck.
    Sorry but, I think this PDF Files are Copy Right Files from other Web Site.............
    It would be nice for you to remove them as they are following up now a days...........(For your own Safety reason).........then its up to you...........
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  7. #82
    Quote Originally Posted by Ashraf6119 View Post
    hi mate,, of course I would take your valuable advice, but this way I have to remove about 50% of my posts since they all had many copyright protected files and programs, so what is your advice about that too.
    thanks for your kind reply and have a merry xmas and happy new one
  8. #83
    Ashraf6119's Avatar
    UK
    Once you have post it and the person has already read it I would advice you to remove it.......... safe for you as well for the forum...........
    As I said Copy Right Company's are following it very much now a days because that's where they are now making more money by suing people............
    That's what I do, post it then remove it don't let it be there............
    Thanks Ash
  9. #84
    Romania
    feedback
    I tried pinkfloyd5eg soft to program pic erased by 100315 but it didnt work for me. I selected right com port but nothing happened. Mine didnt erase or write other stuff to ftdi.
    Astra g Y17dt
  10. #85
    Dec 2011
    i have also installed the latest version of op-com and it installes the driver aswell but when u test interface it tells me to connect the usb or install driver
  11. #86
    Quote Originally Posted by menickb View Post
    The software 110207 doesn't work with clones and doesn't erase them.
    our friend miha99 has shared OP-COM 100219a. which is working with China Clones. (see Post#61 and #62).
    happy new year.
  12. #87
    drakov's Avatar
    Aug 2008
    Yes it does, but you need a high quality clone
    Check out The Number 1 Resource for all Automotive Software with a lot of patience you like me will find what you need...
  13. #88
    Dec 2011
    i have 10029a i just wanted to see if the new update supported any new features as i cant access the ecm option keeps comming up with cant define make from vin or something along those lines
  14. #89
    Dec 2011
    i read on one of the discusions on this forum anout you can connect opcom directly to the psg5 port on the vp44 ecm using pin 12 as + pins 4and5 as - pin 7 on opcom to pin 9 on psg5 plug and - to pin 6 and + to pin 7 on psg5 plug has anyone tried this and been sussesfull as i have tried it but had no joy on the thread it said to press psg5 button and that lost me what is psg5 button? i can connect via can on opcom but get no dtc
    and i also read this
    All 2.0 en 2.2 DTI engines of Opel are equiped with a Bosch VP 44 dieselpump. OP-COM has the possibility to read the error memory of a pump wich is disconnected from the vehicle with a PSG 5 socket (1998-2002). So it is possible to test a disconnected pump with a 12V battery and OP-COM. This software can be used on all the VP 44 (PSG5) dieselpumps.
    on this website
    http://www.stecodiag.com/en/pages/Op...M_prijzen.html
  15. #90
    Land of Choice!
    have you seen the price for the tools?
    atb
