i need more info please
Hi all. While programming a DDEC iv series 60 ecm it lost connection and is stuck in rom mode. When i try download a cal file it runs through the whole process but fails the end and gives me a Fram error.
Help please. Thank you.
Thank you Diesel user 97 for your help.
I have a ddec iii in boot mode and need the following program please.
06R0357148
6067GK60
11.1
6N4M 6409
6N4D 6002
ECM 9.02
S\V 106
Would really appreciate help.
Have a good day all.
Nearly a year with no response, eh?
I'm having what I believe to be a similar problem. Using ddct I uploaded the cal from my ECM, found one I wanted to try, converted it to same metafile, downloaded, now nothing!
Sent from my moto e6 using Tapatalk
Ddec4, it seems to be blank. Not able to connect to DDEC
No fault codes
Whiterhino (20th October, 2021)
ECM had a Rel39 . I converted a cal file to rel39, downloaded to ECM
Whiterhino (28th September, 2021)
Where do I find the program file? Also, DRS is compatible with DDEC4?
Wayne Techiemec (8th July, 2022), Whiterhino (20th October, 2021)
I had it already, I just had to uninstall DDRE to install DDRS. Seems that the keygen.exe i have isn't working. Only have access to trial version, so program device option is not available. On a positive note though, the DDRS is able to connect to ECM.
What is the procedure to "reflash" the ECM with PRG file?
Also, what is the cause of the error? Are the calibrations incompatible with the ECM? Does a mismatch in minor versions cause the problem?
